Question about Packard Bell GCD-R580B (gcdr580b) Internal 8x CD-ROM Drive
Packard bell CD rom
CD tray opens and closes fine, but would not read any form of CD or DVD. Also this drive is not recognised when I open ' my computer' ( ie the icon has disappeared)
Also when I check the drive in Device manager, I could see some yellow signs on the drive ( either yellow question mark or exclamation marks)
Can any body help with this.
  • dino1967 Jul 08, 2008
    my cd/dvd drive is not reconized when itunes is installed, when i removed itunes everything worked fine again.
  • 101 Answers
Cheak cd rom data cable pluge in maight be cable is unpluged and verify the port connection also
Posted on Jul 08, 2008
Packard bell PC DVD rom won't open
Not quite sure what you mean ? which button on top (power button)
The button on the dvd is the only one to open it.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive.
Jan 15, 2014 | Packard Bell Computers & Internet
I cant get my dvd drive to eject, and its not recognising that there is a disc in the drive. I do not have a small hole to stick a pin inside as instructed by others as my pc is a PB OneTwo L5710 and as...
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 20, 2011 | Packard Bell Computers & Internet
Drop down front packard bell how do you insert the dvd
If your trying to open the CD tray to put a CD in and you can't find or the button to open it doesnt work. You can go into the "My Computer" and right click on the CD-Rom drive and select "eject" to open it.
Hope this helps you out.
Best of luck..
Nov 19, 2010 | Packard Bell ixtreme 9222 (P491000102) PC...
DVD ROM MISSING FROM PC USING NERO/CD BURNER XP ETC.
dvd rom drive only writes cd not dvd dvd can be written by dvdRAM
Jul 07, 2009 | Computers & Internet
DVD-CD DRIVE D MISSING FROM NERO APPLICATION ON PACKARD BELL PC
Just perform this
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
If not reseat the drive once and check- that should work,
Or if you have a known good drive, swap the drive with this unit and check.
If the new Drive works fine, the opticle drive of this unit must be gone bad.
Jul 06, 2009 | Computers & Internet
Packard Bell computer won't play dvds.
This sounds like a common problem. You need to install the drivers (small programs that instruct the computer to notice and manipulate peripherals, like a dvd or cd player, sound card, etc...).
The easiest place to find your specific driver is at the Packard Bell web site under support > Downloads. There are MANY sites (even some that advertise on this very site) that say they have the drivers for your dvd drive, but go directly to your manufacturer's web site. These companies that provide drivers for computers install a program into your computer and there is a fee for use of these web sites.
UPDATE: I just checked the Packard Bell Web Site and was unable to find specific drivers for your particular model. They stopped making them some time ago, and no longer support the model. That being said, you can still conceivably find the drivers, it will just take some investigative work on your part. In doing a broad search on the internet, I found that many people are looking for that very driver, which is an indication it has become hard to find.
Jun 15, 2009 | Packard Bell GCD-R580B (gcdr580b) Internal...
IMedia B2217 PC: DVD lid flaps down but drive
There should be a little pinhole located under the door on the bottom of the tray. Push a paperclip in the hole to get the tray open. After the tray opens, close it and see if you can open it normally, if not it's broken and needs replacing.
Apr 26, 2009 | Packard Bell Computers & Internet
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Cd rom
its very simple .remove the outer cpu case.then remove the cd rom open itplace THE TRAY in RIGHT MANNER ONCE AGAIN . donot try to move the tray of your cd rom without opening the cd rom ,it might result in a permanent damage
Nov 03, 2007 | Packard Bell GCD-R580B (gcdr580b) Internal...
No playing CDs
go to website of bell computer 1. find the latest BIOS and download it to your computer 1. find the latest driver for your CD model and download it Good luck!
Aug 17, 2006 | Packard Bell GCD-R580B (gcdr580b) Internal...
Packard Bell GCD-R580B (gcdr580b) Internal 8x CD-ROM Drive Logo
419 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
