To make recordings on your phone is quite simple. All you need to do is to go to the phones menu, select multimedia, then in the multimedia list you will see recording, then you select it, you can either make video recording or audio recording.
When you are ready just select the record button.
Shortcut to recording a vidoe, just open the camera from the menu, then you select option and select video recording, it will bring out the record option and from there you can record the video you are willing to make.
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 1234 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
go to phones settings and select the restore factory option and put 00000000.......u rphone will be automatick restart..den ur this problem will be gone
