Question about Cyberhome CH-DVD 300 DVD Player
Won't read/initialize CD's or DVD's.
My CyberHome CH-DVD 300 will not read cd's or DVD's. Once the disc is loaded, the disc spins, the video screen says "read", but will not play the disc. Also, after attempting to read the disc, the disc stops spinning and the thin square LED next to the load tray flashes alternating red and green.
If I take the top of the case off, the lenses look clean. I blew them off with dusting air, but no improvement. If I manually slide the lens assembly all the way to the outside, the assembly WILL slide front and back trying to read the disc.
Any ideas?
Thanks
  • krajesj Jul 01, 2008
    Hello, and thanks very much for your reply so fast.
    I looked on the power supply for such a capacitor, but there was none that fit that description, either in appearance or value. There are only two outputs from the power supply board, +5.0 and +12.0 VDC. Mine reads 4.98 and 11.8 VDC.
    What next, please?
    Thanks,
    Steve
  • 24 Answers
Clean the lens with soft cloth by hand, if problem persist then check lens stripp connecting to m board, if still problem change the lens.
Posted on Jul 02, 2008
    Genius:
  • Cyberhome Master
  • 1,550 Answers
Check for a dry capacitor on the power suply is about 16v 470mf you can identified him because the top are inflate.
Posted on Jul 01, 2008
  •  Francisco Mauricio G
    Francisco Mauricio G Jul 02, 2008
    Check the flat cable who connects the mainboard with the laser sometimes is broken check continuity on their terminals.
My CyberHome CH-DVD 300 Player Not working CD, Only Disply "CyberHome DVD appear in Screen". I am in Near Tambaram. Please send Nearst Service centre Contact No. and Address.
Not reading anymore DVD movies disc or CD musics disc.The DVD laser eye head reader it is dead.Can't be repair must be replaced,not worth it well cost the same price as a new DVD player unit,if repair by a tech and have to buy parts for it.Basic DVD player unit are very cheap these day.U can buy a new one just a basic DVD player only will cost u like $40.
Aug 22, 2011 | Cyberhome CH-DVD 300 DVD Player
My disc tray won't open the lights turn on and work but the disc tray just won't open. How can I fix this?
hi,
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
ok
May 05, 2011 | Cyberhome CH-DVD 300 DVD Player
Cyberhome chdvd 415 does not read dvd says no disc
That might be a problem with your len which it is very popular today, try cleaning you len with a lens cleaner cd.
Dec 29, 2009 | Cyberhome CH-DVD 300 DVD Player
Cds fine; dvds won't load
Most likely the DVD laser lens is dirty. Unplug the CH-DVD 300 from the wall outlet, wait 5 minutes, then remove the top cover. Next, remove the rectangular metal plate which covers the area where the CD or DVD disc would be when in the player's tray. Underneath the rectangular plate you should see two small lenses. Gently clean these lenses using ear swabs moistened with isopropyl alcohol. Reassemble the CH-DVD 300 in the reverse order that you disassembled it, plug it back into power, and now it should read your DVD discs just fine.
Aug 13, 2009 | Cyberhome CH-DVD 300 DVD Player
It won't read disc. After loading, it reads No Disc
Sounds like a read error fault , possibly a laser malfunction sometimes dirt on the lens will cause this try a good CD cleaner if this is no good I suggest a free engineers estimate at least you can then ask again on here how to fix it . My honnest guess is either a duff laser or software corruption . I have known seating of the tray to cause this also not returning fully back into machine , usually caused by children and alien matter ? shall we say such as choclate or M&MS kids shove stuff everywhere ? bless them lol
hope this helps Regards Vortash
May 10, 2009 | Cyberhome CH-DVD 300 DVD Player
I have a CyberHome DVD 300. It will not load disc.Indicates that no disc inserted. I have cleaned the disc to no avail.
you will need to remove the cover and clean the laser eye with rubbing alcohol and cotton swab (q-tip)
Mar 04, 2009 | Cyberhome CH-DVD 300 DVD Player
I cannot get my Cyberhome DVD to work
Hello
I have a cyberhome dvd player CH- DVD 300 had it for a 1 year i but in a orginal dvd movie and it does play it it said no disc I but in dvd cleaner it read for a moment but when i put in the orginal movie it said no disc again is it the sensor or what, what should i do???
Aug 18, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 can't read CD
Why don't you call manufacture and see if can get service.
Jun 08, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
90 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
