Question about Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range
Dacor Epicure ERD36SCH Dual Fuel Range
Unable to input an oven temp setting. The display runs past the desired setting even though I've stopped pressing the up arrow. The oven does not come on.
The oven light operates intermittently on its own.
Unable to set the clock.
Cooktop's igniters intermittently fire on their own.
5 Suggested Answers
SOURCE: dacor range natural gas to LP
I have the ERD36 and it runs on LP. Is this purchase a used oven? If not, I would tell the dealer to order it for LP.
Posted on Jan 27, 2008
SOURCE: how do I convert a dacor epicure range ERD48 from
Just change the orifices. Also adjust the pressure control regulator by reversing the built in plastic spacer, the regulator supplied is a dual fuel type. Any work should only be carried out by a person who is qualified to do so for safety reasons. Dacor are very unhelpful when I posed the same question directly to one of their technical advisors. The poor level of this persons 'technical' knowledge both surprised and concerned me.
Posted on Jan 30, 2010
SOURCE: How to replace glass on oven door - Dacor Epicure
You need to take the door off. There little hooks on hinges, that you move to up position and then lift up the door and it comes out. After that unscrew allt he screws, that you see.
Hope it helps.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: F1 flashing on Epicure 30" Dual Fuel range and Gas-flame broiler
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Temperature fluctuates in bake setting. Temp on display does not match real oven temperature.
as long as your measured temperature is within 15-25 degrees of shown temp, then it should be ok. remember the temp in the oven will be different from top to bottom.
Dec 11, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor dual fuel range (ERD36SBK): Electric oven coil and broiler does not go on, but the control panel on the front of the oven looks like it everything is operational. There are no codes showing. When I...
It could be the oven ignitor which is located under the heat displacement shield if you have a voltage meter or a multimeter do an ampere test should first shut the gas off next locate the oven ignitor or bake ignitor and you will see two wires that go to the ignitor clip around one of the wires should be reading 3-3.3 amps any less then this and the oven will not light even if it read 2.9 it would still be a weak ignitor and need to be replaced because it would not be lighting the gas when it was supposed to check your oven ignitor and message me back with your finds And please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again and Happy New Year
Rick
Dec 29, 2010 | Dacor Epicure ERD36 Dual Fuel (Electric...
Hope it helps.
Feb 07, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor rsd305
yes, you need to open the panel (in the center of the front of the oven when you open the door on the top) and press the reset button, there is a site that gives step by step instructions, but i can no longer find it
Jul 22, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor ERD36SCH/H will not self clean
Door lock motor suonds like it is bad. Not an easy part to replace. You may need a technician.
May 12, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor range natural gas to LP
Jan 16, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range Logo
153 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
