Question about Dishwashers
Kenmore garbage disposal
When I turn on my garbage disposal I hear a humming noise coming from the motor. I turned it off, pushed reset button but hear the same thing. Earlier this week I did hear like something was in there but everytime I put my hand in there, I felt nothing blocking the way.
Recently, it won't start. I have tried to find something lodging, but haven't felt anything. I even filled up kitchen sink with water and plunged thinking that if something is lodged it would be dislodged, but no luck.
Any suggestions would be greatly appreciated. I had great luck and saved much money coming here and being able to fix my front load washer. Thanks!
  • 1 more comment
  • rak80 Aug 05, 2008
    I have the same problem, but I think it's more than just a simple jam. I've taken the unit out, turned the hex wrench until it's free both ways, but when I re-install it, it works for a second or two, then stops and hums. It's my opinion that the plate inside is loose. I have repair parts that came with the unit (when I bought the house) is there a way to take it apart? I can't seem to get into the guts of it other than the electronics at the bottom.
    Rich
  • rmandrums195 Apr 22, 2009
    I have the same problem also and I have also used the key on the bottom and the blade inside rotates freely. So I KNOW FOR A FACT, that nothing is jamming it. So does anyone else have a better suggestion than the answer given?
  • jmacuk May 11, 2010
    aehess' solution was spot on! Unplugged the unit and removed the offending jam (a small teaspoon). After plugging back in, disposal ran but made a horrendous noise: one of the grinding teeth was loose. Stuck a carrot in and ran again; noise quickly died and everything works beautifully again.
    Novelist:
  • 161 Answers
Most Kenmore garbage disposals are made by In sink erator. There should be a hex wrench hanging under the sink. This fits into the hole in the bottom. this allows you to turn it by hand to free the jam. Go to Home Depot or something like it and buy one. If this is another brand take a broom stick and stick it in and try to turn the grinder plate. When you get it to turn freely. reach in and see if you can feel anything. Remove if present. Once the grinder plat turns freely it should start. (Use reset button if needed)
Posted on Jul 03, 2008
I have the same problem. I took the unit apart and it appreas that there was a screw in the basket at one time that has come loose and is now missing. The basket (wall) of the disposal has a seam in it that is secured by this screw. Even if you could match up the screw you would probably have to take apart most of the disposal.
Posted on Jun 20, 2009
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
I get power through the reset button. No humming, no nothing. Is it a bad motor?
If i understand correctly, you tested the wires where they connect to the garbage disposal.
Those wires connect before the garbage disposal reset button.
If the reset button is locked in, then the reset is not popped out.
If reset will not reset, then the popped-out reset will push in but not click down.
If the reset is clicked in, and you hve 120V on the line, and the garbage disposal doesn't make any noise, then the motor is bad.
There are no replacement parts for garbage disposal.
Oct 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposle makes a humming noise when turned on. InSinkErator Badger 5, 1/2 HP Garbage Disposal
Did you also hear any clattering sounds when it started? If so, it is rotating. If not then this hum is the motor in the lock rotor stage. Did you place garbage in it yet? Always run cool water in it when starting it.
May 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The motor on my Badger 5 disposal was humming but not rotating. I cleaned out all the debris, reset it and now there's nothing - no hum, nothing. Is my badger dead?
The badger 5 has a dislodge device on the bottom right in the very center. An allen wrench will fit if you have lost the tool that came with it.
FIrts you will need to dislodge anything preventing it from turning. (Insert the right size allen wrench and turn both directions) The remove whatever comes loose after dislodging.
Then opush the red reset button on the bottom. Check the breaker that powers up the disposal, as you may have tripped it.
If the breaker is on, the unit is turning freely, and the reset button is pushed, then the next step is to check for power using a volt meter, to make sure the disposal is indeed getting power. If all the above has been done, the unit IS getting power then yes, the disposal needs to be replaced.
Oct 11, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My garbage disposal is not working. Making humming sound when turned on. I tried to press the red reset button but to no avail. Also tried to turn the little dosposal wrench in bottom hole of disposal but...
It is most likely plugged up there is a clap with a butterfly bolt that you turn counter clockwise remove the clamp and have a trash can under it and wiggle it to remove the lower half of the disposal, when it comes off dump it out and clean with fresh water. Then with hands free of the pump turn the disposal back on, it if still hums the motor is bad and you will have to replace..
Sep 13, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal hum
Hi, Hit the reset again. It sounds like the cutter is lacked up some way. Try using a long wooden spoon ar something simular and see if you ca free up the cutter. If the cutter is free and it still will not work, you will probably need a new disposal. If you are getting no noise after you hit the reset, chack your breakers to make sure there is power to the unit. I hope this helps you. Please let me know if I can assist you further.
Thaks
Vic
May 14, 2009 | Kenmore Dishwashers
Dishwashers Logo
4,091 people viewed this question
Top Dishwashers Experts
