Question about Phase Linear UDV9010 Car DVD Player
  • 43 Answers
Check fuse on dvd because there is no reason that does not work if the new installations carried out and if everything is well connected.
Posted on Jul 01, 2008
Had the face off of the dash and wires were moved around. the radio doesn't shut off with the key and it did before and the battery light stays on
Sounds like the acc wire has been hooked to constant power. It needs to be hooked to a switched power source. A circuit or power wire that is only on when the car is. Sometimes that can be a cigarette lighter or a circuit in your fuse box. You will need a digital multimeter to find the circuit.
Apr 15, 2016 | Car Audio & Video
No power to fuel pump on 1995 chevy s10 2.2 truck
it might be broken wire have test the wires with a meter or test light
Nov 30, 2017 | Chevrolet S 10 Cars & Trucks
No source keeps popping up?
what type of unit you have if its a lowrance 5 7 8 10 12 you have got to have both yellow wires to both units hooked to the red wires to both units meening hook the yellow and red wires all together but make sure you have this hooked to a switch you can turn off and on like main power if not it will stay on all the time
Sep 06, 2011 | Lowrance LSS1 StructureScan Sonar (Lss1...
XO VIson DVD 7" works fine but when it is turned
sounds like you might have the wire that is always supposed to have power hooked to a switched power source
is it possible you hooked up power wires wrong
sounds like switched wire is hooked to battery and battery connection is hooked to switched source
only other option would be if ground is hooked incorrectly it should be hooked diretly to clean non painted metallic spot on cars body
if you need more help give me more details and i will try to help more
Good luck
Mar 13, 2011 | Panasonic XO-1515 XOVision Car DVD/CD/MP3...
I need to know which colour wires are the power supply on a nissan almera 1999 ambition radio harness
Normally,orange needs to be hooked to a constant 12V source straight from the battery(called constant).This will keep your presets and time running when the car is off,which is also normal.Red is hooked to a wire which gets it's power from the ignition being on,also called switched power.
Good luck,Greg
Nov 03, 2010 | Car Audio & Video
I have installed a new car radio and when the ignition is turned off the radio stays on. I have to manually switch it off and then it looses all of the preset radio stations. The radio instruction books...
Sounds as if you have power wire hooked up wrong. Should be 2 power wires. Probably a red one witch should be connected to Ignition on only power source, This your main power. Should have a yellow wire, which is memory backup which should be connected a constant power source In othe words hot all the time even with ignition off. You can use a test light to test power points.
Feb 15, 2010 | Car Audio & Video
T101 R Clock will not turn
The "Line" is the power source. The "load" is the device that is being powered.
typically the green wire is the ground wire. I strongly urge you to verify your assumption that is is the common wire. If the green is indeed the ground, and it gets hooked up to common, you will be energizing the cabinet of the unit and posing a serious shock hazzard.
Your curcuit will be as follows.
The power source "Line" will have wires going to the timer. (hooked to the "line" terminals on the timer.)the timer then is supplying the power to the pool pump, and we will reffer to it as the "line".
The two black wires from the pump would be hooked up to the "load" side of the timer.
Typically they would be labled line 1 and line 2 or "L1" and "L2"
If yours are not labled so, describe exactly what terminals you have in detail in both the pump and the timer.
Oct 03, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Dual MXD55 W/6/5 SP CD Problems
make sure the speaker grounds are connected to the speaker ground wires on the deck and not the "chassis" ground. also make sure both power wires are hooked up to a power source. the thinner power wire is supposed to be a switched source (like the ignition key or an accessory switch) that turns the unit on and the thicker one is a constant source which actually powers the deck once the switched source is turned on.
Jul 01, 2007 | Dual MXD55 AM/FM/CD/Weather Receiver
Phase Linear UDV9010 Car DVD Player Logo
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
