Question about Canon PIXMA iP4000 InkJet Photo Printer
Flashing orange light
Hi! I usually can fix my own problems with this printer. This time I am stumped, because I cannot find my manual since I just moved into a new home. The error is referring me to my manual, it is telling me that it is a service error Service error 6A00.
Cancel printing and turn the printer off and then back on.
If this doesn't clear the error, see the printer manual for more detail.
I did all this but, don't have them manual handy. Can you help?
    Sergeant:
  • 305 Answers
It may be that your printer is due a service. depending how often you use it, i had a similar problem with an epson, every so often the printer needs to be serviced to empty the residue ink tank, this is a small tank that collects all the odd drops of ink, when overprinting, head cleaning etc. it could be just that. thats all i can think of, hope it helps
Posted on Jul 01, 2008
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Canon iP 5200 orange light flashing 5 times
Hi
IO have one of these printers as my daily workhorse. Thankfully I haven't had the problem you are having.
Did you remove the print-head from the printer and clean it with running warm water?
When I get a possible print-head problem I always do that, rinse it until the water runs clean. Then dry it on kitchen roll making sure that the contact on the back are completely dry before refitting it to the printer. Generally this has cleared any problems (I have several Canon printers - I'm not just referring to the 5200 now).
However If you still get the error it may be worth contacting your nearest Canon service centre. New print-heads are not exactly cheap but these printers are so good it's worth keeping it going. They will probably be able to diagnose the problem quickly and accurately and tell you if it is cost-effective to repair. I don't know what would be involved with the Eprom error. - probably a circuit board change inside the printer.
Dec 22, 2009 | Canon Office Equipment & Supplies
Printer is flashing orange in equal increments. When printing, I get the error message 6A00. It tells me to turn the printer off then on again. I turn it off an on again, but this does not fix the problem....
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 02, 2009 | Canon Pixma iP4500 InkJet Printer
My canon ip1880 printer orange light flashing 7 times even after I have installed both my cartridges correctly.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Oct 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
All Lights Flashing
Your printer need service. Its firmware problem. All lights flashing error state usually indicates a hardware problem of your printer.
Aug 04, 2009 | HP OfficeJet D125xi InkJet Printer
Yeess
Press and hold the resume button for 5 seconds
Oct 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon i250 flashing orange / green light
turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
Feb 17, 2008 | Canon i250 InkJet Printer
Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Jan 29, 2008 | Brother HL-5240 Laser Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
102 people viewed this question
old marine
old marine
