Question about GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur...
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
Freezer temp varies from -25°F to +20°F and refrigerator varies from 32°F to 45°F during a few hours. It won't hold a steady temperature on either side. It's about 3-4 years old. Thermostat sensor and temperature control panel have been replaced with no effect. Temperature settings in refrigerator seem not to be able to correct these extremes. My GE Profile is 2 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units. I have had two MB "upgrades" replaced in the past 7 days to no avail. It's unbelieveable GE can't figure this problem out. And they produce jet engines?
  • 796 Answers
Its just blowing warm air in the freezer section?
No frost build up on the inside back freezer panel?
This link will help you troubleshoot it:
http://www.applianceaid.com/refrigerator.html (http://www.applianceaid.com/refrigerator.html)
Posted on Jul 01, 2008
    Brigadier General:
  • 3,614 Answers
If you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
My GE Profile Side by Side Refrigerator (PSC23MGNA) has ice below the bottom try in the freezer. I tried to thaw out the area on the back but I am not sure where the drain is located. Need Help on wha
drain is located in very back of bottom of freezer an a little ledge 6 inches from bottom.... ice build up normally means drain is clogged and needs hot water / turkey baster to force hot water down drain. (gently chip away ice careful not to crack plastic
Aug 28, 2014 | Refrigerators
Ge profile artica model PSC23SGPA Side by Side not keeping temp - lost everything in freezer and now frig is heating up. Can change temp to 0 but within a few seconds reads 24 (temp set does not hold)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PSC23MGNA refrigerator. No display light for
Sounds like you have a bad main control board . The original pt # is WR55X10552 . The replacement board is WR55X10656 . Your original board , is on a recall list , and GE should come out and replace under an extended warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Oct 31, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Jun 17, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur... Logo
442 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
