Question about Bogen Communication Bogen Manfrotto 322RC2 Grip Action Ball Head Tripod
322RC2 The friction on the ball head is fine but will not lock when grip released. Grip action feels normal. Thanks Jeff
  • jkmcfadd Aug 24, 2008
    Exactly the same result! Right down to the small black piece of plastic falling out. Thanks for THE solution.
    Jeff
I just had this same problem and came across your post.  In frustration I held the grip and then let it go very quickly where the grip 'snapped' back.
Now it works.  Go figure.  I will mention a very small piece of plastic fell out of it, but it does not appear to hinder the functionality.
Posted on Aug 24, 2008
Friction control stuck
Send it to these guys for repair: http://www.manfrottotripodparts.com/repairs.html
There is a pretty hefty spring inside that will shoot out if you are not careful. Don't do it your self.
Jan 29, 2014 | Manfrotto 322 RC2 Grip Action Ball Head
Ball slipping
Check out this page and see if there are any parts here that might be what you're looking for:
http://www.bogentripodparts.com/parts/head322RC2.htm
However, I'm not sure there's a way to fix a ball head tripod due to how the tension works for the ball that it rests on. You can also order a new head from the same website. If you have any questions, shoot us an email at email@spartanphotocenter.com
Nov 21, 2012 | Bogen Communication Bogen Manfrotto 322RC2...
I have a Slik AF2100 and the locking devise does not hold strong enough, ie the grip on the ball is lose and the cameras weight is making the ball slip, is there a way of getting it tight again? Cheers
Hold the yellow trigger in slightly to release the ball head, then rotate the section with the ball clock wise until the grip on the ball suits your camera setup.
Mar 26, 2011 | Slik AF2100 Pistol Grip Head with Quick...
Tripod & Head attachment
You weed the 520 Ball also called the 3284 Bowl with 75mm Knob
that can be found at the bottom of this page: http://www.bogentripodparts.com/heads.htm
May 02, 2010 | Manfrotto (Distributed by Bogen) 055XPROB...
My 322RC2 Grip Action Ball Quick Release has lost
I had the same problem and found the solution after much looking online. Use rubbing alcohol to clean the ball! This works even with the ball in place as long as you rotate the head around to reach all surfaces of the ball. Note that many suggestions to tighten the Allen screw at the base of grip clamp or to roll the wheel to its tightest position do not work because they affect the amount of effort you need to squeeze the clamp, and not specifically the amount of friction between the ball itself and the head. Over time the ball loses it's grip but rubbing alcohol removes finger oils, dust, airborne pollution, etc. After wiping with rubbing alcohol, my ten year old head is now as tight as the day I bought it! Hope this works for you.
Apr 03, 2010 | Manfrotto (Distributed by Bogen) 190XPROB...
It is constantly loose will turn easily without depressing the handle! Ive had it for a few years now and it started doing it this year. I use it with a tripod mounted Leica Spotting scope and it has been...
The normal tightness adjustment is black and on both sides of the handle. There is a plus and minus sign above it on the left side of the grip to show how to get more and less tightness.
There is a SECOND adjustment that I just found on the back side of the handle (opposite side from the gray grip on the front). This one requires a very small allen wrench to tighten (clockwise). I assume that this one was designed as the rough adjustment and the upper one is supposed to be for fine tuning during a photo shoot or normal use.
Either way, I'm glad I don't have to replace my tripod head. She's been halfway across the world with me!
Nov 01, 2009 | Bogen Communication Bogen Manfrotto 3265...
Need a user guide for a Manfrotto Bogen 3265 grip action ball hea
Hi, This should get you to what your looking for, Go to this web site : http://www.manfrotto.com/Jahia/spareparts/site/manfrotto/cache/offonce
Feb 25, 2009 | Nikon TRIPOD, BOGEN PRO WITH PISTOL GRIP
Manfrotto 322rc2 tripod ball head
here is manfrotto's "How To" site, they have illustrated how to use almost all of their products.
http://www.manfrotto.com/Jahia/site/manfrotto/cache/offonce/pid/2475
hope this helps out. if you have other questions please lemme know
Nov 04, 2008 | Bogen Communication Bogen Manfrotto 322RC2...
Manfrotto Tripod Ball-grip Head 322RC2
If you look on the ring that goes around the ball, on the side by the red tension gauge, you'll see an indentation. It is just barely visible on the product shot above.
In the hole, you'll find what looks like an odd shaped bolt. It is actually a threaded post inside a nut.
Use an Allen wrench (hex key) to tighten this post.
Be careful though, a little tension here goes a long way. You should probably turn it no more than 1/8 to 1/4 turn and then test it. If it still isn't tight enough, repeat until you are satisfied.
You should probably also talk to a trained technician at somepoint to see if the loosening is indicative of a larger problem. I really wouldn't know one way or the other. I just discovered the calibration post by taking mine apart.
Sep 29, 2007 | Bogen Communication Bogen Manfrotto 322RC2...
Photography Logo
414 people viewed this question
Top Bogen Communication Photography Experts
pontelemon
pontelemon
Tony
Are you a Bogen Communication Photography Expert? Answer questions, earn points and help others
