Squeeking fan on power ventilation my unit is a AW1400A/XAA, when I turn unit on it squeeks. It sounds like its in the squirrel cage or fan.
    Genius:
  • 1,036 Answers
Hi there!
This is almost certainly a dry bearing on the fan motor. If there is little or no oil on there, a little rust may form and the next time this is powered up, the rust comes off - but is polished onto the bearing - creating the squeek.
Buy a can of maintenance oil in a pressurised can, and squirt some on the bearings at each end of the motor. It doesn't matter if it drips or runs down anything. If there are 2 separate motors - you need to oil 4 places.
If the unit is very old, it may use a motor with brushes. I'll give more details if the oil doesn't work.
Thanks for using Fixya - and if this works, please rate as such.
Posted on Jul 01, 2008
Why does my ac freeze up
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
Jul 09, 2012 | Danby Heating & Cooling
Ac squirrel cage fan motor noise
Could be bearings going out, or a squirrel cage rubbing the blower housing, a squirrel cage blade that came loose, or a capacitor.
Jun 12, 2012 | Bryant Heating & Cooling
When I turn on the A/C or the heater in my my 1995 Regal a sound is made like the fan blades are brushing against something. I believe something fell against the fan. Any idea how to access the fan?
The fan cage(blades) are bad,you will have to replace the squirrel cage,and you may have to buy it as a whole unit to get the squirrel cage.If this was at all helpful,please rate thank you.
Aug 20, 2010 | 1998 Buick Regal
My Goldstar has started squeeking... not vibrating... squeeking. Any suggestions? It sounds like something needs some WD-40 sprayed on it.
sound to me like the fan motors squeeking may need a little lube these motors are sealed to protect them from the elements it is possible that a lube port exsists on rear of the motor it will have a little plastic plug in it you can oil it there. a good one to use is zoom spout oiler hardwre store may have it wd 40 not good for this app. wont last. if not an old trick i do is tilt the unit with the shaft and condenser fan facing up and put just a couple drops on the shaft you will see it run in DONT USE TO MUCH CAN DAMAGE MOTOR so be careful this should help.
Jul 11, 2010 | Goldstar R8000 Air Conditioner
Running not blowing air
sounds as if fan isnt attached to motor shaft. There is a set screw on the fan cage that if it loosens the shaft will turn inside of the fan not turning the fan( also known as a squirrel cage) You need to get access to the fan motor and see first if its shaft is rotating, if it is see if the squirrel cage is turning if not the set screw located on the inner collar of the squirrel cage needs to be tightened. Thie set screw is more than likly an allen set screw.
Jul 07, 2009 | Heating & Cooling
The blower fan on 1997 Jeep Grand Cherokee squeeks when running.
Maybe that's why they call it a squirrel cage. Seriously, noise is either from something caught in the fan or a bearing in the motor is dry and beginning to fail (motor needs replacement) Either way you need to remove motor to check it.
May 11, 2009 | 1999 Jeep Grand Cherokee
Rheem A/C unit makes a clicking sound when
Shut down the unit and turn the power off. Take the cover off of the blower housing and feel around within the squirrel cage. It sounds like something may have been drawn up into the blower. Also it is possible that the blower wheel might have thrown a balance weight and caused the wheel to become unbalanced. It could also be the motor about to go out but since I can't hear it myself, I'm trying to cover all the bases.
Mar 22, 2009 | Heating & Cooling
Squeeking noise from unit when u switch set on but no picture?
Sounds like the HV generator will need to be replaced. Can you tell if the sqeaking is coming from this component without touching it?33c0a28.jpg
Feb 01, 2009 | Televison & Video
Defective squirrel cage fan
Upon searching further, I found parts for the unit. www.appliancefactoryparts.com
Part CRCFD5303-010 Fan - $19.99
Part CRCFD3000-030 Motor - $49.99
Aug 03, 2008 | Maytag M7DH45B2A Dehumidifier
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
