Question about Nikon D80 Digital Camera with 18-135mm Lens
Using a speedlight sb800 off camera on a Nikon d80
Hi How do i set up both flash and camera so i can trigger my flash remotely using the D80 - i believe it is possible to set up a single chanel to do this but can't find how in either manual - help!!
  • stevekohler Jul 22, 2008
    Thanks also found a thread on flickr will try both these and see how i go -- thanks again!!
Found a great website that explains this since it's not in any of the manuals or other websites I have searched for so long!
This covers the D70 and SB-600 which I use personally. It should be similar on other cameras. Any questions? Presuming you have USA equipment, call (800) NIKON-UX for details.
On your D300:
Press MENU.
Move up or down to: PENCIL menu.
Move right and down to: e Bracketing/Flash
Move right and down to: e3: Flash cntrl for Built-in Flash
Move right and down to: C Commander Mode
On your D70:
Use P, S, A or M exposure mode.
Press MENU. Go to the yellow wrench menu, and be sure CSM MENU is set to DETAILED. Otherwise you won't see the next setting!
Go to the CSM menu which looks like a purple pencil. Set #19, Flash Mode, to "COMMANDER MODE." Further click to the right to set the commander mode to "TTL."
You also may set the commander mode to Manual or AA, which are other modes to fire the remote flash. The SB-600 only works with TTL and Manual. You set the manual power level at the camera.
Don't forget to POP UP THE BUILT-IN FLASH!
On your D200:
Press MENU.
Move right and down to: e3: Built-in Flash
Move right to get to a confusing panel of C Commander Mode settings.
Once in this confusing panel you can set everything for two external groups of flashes and the built-in flash. You move between the different fields by moving left and right, and set any field by toggling up and down.
In this panel you must select Channel, and set it to 3. Default is 1, which is the default for the SB-800. Don't ask me why they are different. Default for the SB-600 flash is channel 3, so if you forget this it won't work! Sorry about the complexity; Nikon didn't ask me for help here.
This is such a pain I use one of the D200's setting banks to store this.
On your SB-600:
Hold down ZOOM and "-" together to enter the CSM settings. That's why you see a gray "CSM" marking between those two buttons.
Press either the + or - buttons until you see an icon that looks like a wiggly Z-shaped arrow. This arrow refers to wireless communication between the flash and camera. When you see the wiggly arrow, press MODE to make it say ON.
Press ZOOM and "-" together to get out of the CSM mode. Even easier, just tap the power button to get back to normal operation. It won't turn off if you hit it while in the CSM settings.
Presuming you did this correctly you'll see "CHannel 3" and "GROUP A" displayed. If you see different channels or groups then press MODE to get one or the other to flash and then the + or - buttons to set them back to 3 and A. No, I have no idea why these are the settings you have to use instead of 1 and A; 3 and A are what you need to talk to the D70's built in flash. If you get smart and choose others then it won't work. The other channels and groups are for people much smarter than I who want to try to rig up a zillion flashes to work together and control them all separately and remotely. I prefer professional studio strobes if I'm using more than one strobe at a time.
The SB-600 doesn't go into standby in this mode, so you can run down your batteries if you forget and leave it this way. It just sits there blinking its little red LEDs visible from the front.
Easy, just shoot! If you set everything to TTL as I suggest then the camera just does everything. You and I are free to concentrate on the more important parts of making a great image.
Everything is controlled from your camera. This is very convenient if you have the strobes someplace remote, like duct taped behind plants.
You can control the remote flash's output simply by varying the flash exposure compensation control on the camera. You can do that without taking your eye away from the finder! You do that by pressing the same button you used to pop up the flash and then moving the front control wheel. You'll see the amount of compensation on both the camera's top LCD as well as through the finder. Brilliant! You can add more or less flash fill without having to walk over to the remote flash.
You can set the mode (TTL, Manual or AA) from the camera.
You can set the manual power level from the camera as well.
Try to have the little black window on the bottom right of the flash (marked with that same wiggly arrow) pointing in the general direction of the camera. Thankfully it's not a big deal; you don't even need a line of sight so long as the flash is anywhere near the camera or subject.
The sensor is sensitive enough to pick up the flash from the camera even if it has to bounce around a corner or off the subject. This makes this current system so much better than the older ones. You can hide flashes anyplace and even if they can't see the camera they usually go off correctly. They beep to let you know what's going on, even if you cant' see them.
The i-TTL system is much better than the old systems because it just works. If you ever used the older systems you'd know that half the time you'd get no flash, or a full-power flash that also wasted the shot. This new system just works, and that's critical for use in the field where the remote flash is rested on a garbage can or held in your left hand while you hold the camera with your right.
I even can have the flash in a different room out of view of the camera and it goes off just fine.
It works fine even 50 feet away. I haven't tried it any further. Honestly I have no need for a flash that far away; I was just seeing if it worked.
Posted on Sep 16, 2008
    Problem Solver:
  • 7 Answers
Depending on what flash you are using, you can set the D80 to work in "commander mode". You will need to use a Nikon SB-600 or SB-800 flash. When you set up the commander mode you can choose what channel to use. You would then set up your flash to run in the same mode on the same channel.
Posted on Jul 21, 2008
How do I set up NikonD80 and speedlight SB-800 in the wireless mode ?
Posted on Dec 19, 2010
Using canon Speedlite 300TL on Nikon D80 camera
The Canon Speedlite will work, but you won't get the full functionality of a Nikon Speedlight. Most importantly you won't get the through-the-lens metering.
Mar 05, 2012 | Nikon Cameras
I now have a Nikon D80. I have a National Flashgun Model PE300SWG Can you advise me if this 'gun is safe to use with the D80?Nikon tell me that as long as the trigger flash voltage is o--250volts it is...
A flash trigger voltage in the 250V range is fine for most film cameras, but not for most digital cameras. The PE-300 has a trigger voltage in the 33V range, which I (and most others) would consider much too high for the D80.
BTW, "National" is a brand name used by Panasonic.
Oct 21, 2011 | Panasonic Cameras
Speedlight SB-22S TTL Flash: i have a Nikon Speedlight SB 22 that was used on m...
sorry ,you will have to get a flash for dx flash not compatible with digital.
May 17, 2010 | Nikon Speedlight SB-22S TTL Flash
I was using the D80 with an SB-800 Speedlight and at one point the buit in flash popped up. I now cannot get the built in flash to lock in the down position.
This must be because the SB800 was not seated in properly or was turned off when you used the cam.
Use one of the manual settings (A or S) and you should be able to keep the built in flash down (unless it was physically damaged that u need to bring it to the repair shop)
Dec 21, 2009 | Nikon D80 Digital Camera with 18-135mm...
Yes, but not all features may work. Look in the manual under "Optional Accessories."
Dec 08, 2009 | Nikon Speedlight SB-22S TTL Flash
Sb-600 and d80 sync, connecting, off camera..
  1. On the SB 600, activate the custom settings menu by pressing the ZOOM and '-' buttons simultaneously for a few seconds.
  2. In the custom settings menu, set the Wireless Remote Flash option (indicated by a curled arrowhead) to 'ON' (use + and - buttons to toggle between options)
  3. Set the flash mode to Master (do not set it as AA or A)
  4. Press Mode button and select one of the four channels available (ensure that you set the camera also on this channel)
  5. On the D80, from custom settings menu, select Built-in-flash
  6. Set the built-in-flash to '--' if you do not want the flash to show up in the scene
  7. Set the mode of the group to i-TTL (this menu can be used to control multiple flashes in different groups. since you are using only one remote flash, select the group you have set in the SB600)
  8. Set the channel to the same as in step 4
Now you are ready to use the remote off-camera flash.
Jan 24, 2009 | Nikon Speedlight SB-600 TTL Flash
Nikon D80. Vivitar 4600 Flash unit
That particular unit is probably not a good choice for the D80 because the trigger voltage (the electricity which flows from the flash through the camera circuits to fire the flash) is 19.5 volts, according to - this could possibly damage your camera electronics.
You don't have to stick with Nikon brand Speedlights, but get a modern flash which says it is I-TTL compatible for Nikon.
Jan 01, 2009 | Vivitar 850AF for Nikon TTL Flash
I Have a Nikon d80 with a sb800 speedlight
Nov 15, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon sb800 speedlight
The trigger circuit and flash tube needs to be replaced . If you want me to repair this contact .
Berrie Smith Camera Repair
Mar 27, 2008 | Nikon Speedlight SB-800 TTL Flash
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon D80 Digital Camera with 18-135mm Lens Logo
1,689 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
