Question about Nintendo DS Lite Console
Fuse location on nintendo ds lite
Do you have any information / diagrams on the location of the fuses? I have the problem of the bottom screen flashing and the unit shutting down.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • Nintendo Expert
  • 127 Answers
Bottom screen flashing and the unit shutting down is more like a broken top screen or ribbon problem.
The fuse problems usually blink the amber light in your DS each time you connect the charger.
And I am sure you will find a guide looking in google for it, just as I did and there are plenty.
Posted on Sep 28, 2008
Tip
DS Lite stopped working. Green/Orange light Flicker On then Off.
Has your DS lite stopped working? does the green/orange light momentarily stay on? Here are a few tips to help you on your way to repairing your DS lite.
These are the three top reasons for the above faults:
1) One of the screens is either not correctly connected or has devlouped a fault... If one of the screens flickers after you switch it on and just before the green light goes out then the screen that doesn't flicker is causing the problem, firstly try reconnecting it and if that doesn't work you will have to replace it, both screens are avaliable for a reasonable fee on ebay, search for either "DS lite top screen" or DS lite bottom screen".
(if you need help with replacing the screens check out my other tips and tricks I have issued on here).
2) Locate the inductor labled "L2" if this is missing then you will need to either solder it back on if you can find it or else you can buy another one again on ebay for a reasonable fee, search for "DS lite L2".
3) If both the above fail then chances are you have blown a fuse, if you can charge the DS then it is not your "F1" fuse in which case you will only need to replace the "F2" fuse, firstly desolder the old fuse and then solder on the replacement fuse, this should solve the issue. If however the charging light stays on for a very brief time (i.e 1-2secs) then you will have to replace the "F1" fuse, locate the "F1" fuse and follow the sames steps stated for the "F2" fuse. These fuses are also found on ebay, search for "ds lite fuse" and buy the quantity you require.
If you don't have access to soldering equipment or are unable to solder these very small parts (i.e fuse dimensions - 1.5 mm x 0.8 mm and the "L2" inductor dimensions - 2.5mm x 1.8mm x 1.8mm) The is a product called wire glue which is avaliable from ebay (located in the USA) which is fantastic as it is a glue with conductive properties.
You may find guides that tell you to "bridge" the fuses and "L2" inductor but I would strongly advise against this, afterall they are there for a reason and just think what damage would have happend if that fuse hadn't have blown.
Here is an image for the location of the fuses, also if you look just under the power switch you will see the "L2" inductor:
http://www.xdupe.com/assets/images/nintendo_ds/tutorials/ds_lite_fuse/usg-cpu-x3_fuses.jpg
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
My nintendo ds lite doesnt turn o. when i plug the
Its a well know fuse problem, you wil lneed to open up your unit and change the fuse close to battery connactions , serach google for location of the fuse , if you are good with electronics its prestty easy but if you r not just take it to repair center Regards
May 05, 2010 | Nintendo DS Lite Console
Unit won't turn on !
This could be due to several things, the main ones being:
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
My ds will not turn on
It sounds like one of you're screens has broken. What you have discribed is generally what happens one either the top or bottom LCD screen has broken.
If it is the top screen the bottom screen will flash for 1/2 a second and the DS turns off.
If it is the bottom screen the DS should still turn on but with no reaction from the screens. (the Ds will shut down immediatley after turning on)
Sep 17, 2009 | Nintendo DS Lite Console
My ds lite wont power on how can i fix it?
One of you're screens is broken or the F2 fuse has blown.
Check youtube for a video on "how to check my DS lite F2 fuses" there are several available that give step by step guidance on how to do this.
Having checked these (and replaced blown ones) and you're screens are still not working then it is a screen that has blown.
If the bottom screen flashes for a split second when you turn it on then it is you're TOP screen that has blown and needs to be replaced. If it doen't flash then it is you're bottom screen that is broken and needs to be replaced.
Sep 10, 2009 | Nintendo DS Lite Console
Ds lite charge, but green lite will not come on
You have damaged the L2 fuse just below the power button. It is vary delicate and easy to knock of off its placement despite being soldered in.
Double check this fuse to make sure it is still in place and soldered to the contacts on both sides of the fuse.
Sep 08, 2009 | Nintendo DS Lite Console
Power is on but my nintendo ds lite stays blank (black screen) both screens
Did your DS get a small bang?
The problem you are having is the L2 fuse located immediately below the on/off switch when you open up the DS (lower screen).
If you give the DS a very mild rattle you will here it rattling around loose inside the DS (in most cases). A lot of the time this same fuse can be soldered back into place to fix the problem all you need is a soldering iron and a triwing screwdriver (eBay).
If it is this fuse and you cant find it, you should bring it back to Nintendo for repair or your local PC repair shop should be able to help.
Jun 14, 2009 | Nintendo DS Lite Console
How to fix a nintendo ds lite
most likly the bubbles (water) got onto the motherboard and shorted out the system, if you put the charger on the system and the power light comes on then off it's the number 2 fuse, replace the fuse, do not bridge it
Jul 14, 2008 | Nintendo DS Console
Screens not Working!!!
I'LL SAY ITS BROKEN YOU NEED TO REPLACE IT
Feb 17, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
134 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
