Question about Video Game Consoles & Games
PS3 has lines and buzzing sound when played in an upstairs bedroom. When played in a lower room, it is fine.
  • croberson1 Jul 01, 2008
    The room was airconditioned.
  • 1,512 Answers
Hi
I take it the machine stays downstairs and you watch a dvd upstairs?
How are you getting signal upstairs.
Love to hear from you
robotek
Posted on Jul 01, 2008
  • Graeme Ross
    Graeme Ross Jul 03, 2008
    Were you using the machine in that room ,or do you have an AV sender to get the signals from the PS3 to the upstairs room. I ask this because it sounds like you are tuning into the RF signal.
    How is it connected to the TV upstairs. Really need to know this to help you further
    regards
    robotek
    Brigadier General:
  • 3,614 Answers
Kindly stand the unit on the stable place, could be a vibration on the unit can do this sound..
    Guru:
  • 1,894 Answers
This can be due to heating of the unit sir.
please try cooling the unit using external fans
N64 No Picture on Vizio TV
Well it sounds like a coincidence then. Or if it's working on one tv and not another tv then you need to try a new av cable to see if it makes a difference.
Oct 13, 2012 | Nintendo 64 Console
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
Tran A/c installed last summer
It's the ducting that causes the problem. But if the old unit wasn't as bad, did they install a smaller unit to save on money? It is possible, some companies do this to make more money. Sad but it is true. A return added to the room would help but if they can run a return, then they can add another duct or reduct the room as well. Sounds like someone is trying to sell you a story without fixing the issue. Tell them that they don't need to add an extra run, tell them to change the size! Also, make sure that if the run is longer than 25 feet, the ducting has to be stepped down in size to increase valocity to the vent. For example, you have a 10" duct running for 25' and then you step down to 8" the rest of the way unless that run is more than 25'. Hope this info helps!
Apr 02, 2009 | Heating & Cooling
Hot Upstairs
A good heating guy should be able to balance your dampers to increase the airflow upstairs. Keep in mind heat rises. 2nd floors are the hardest to cool. You may need to add more returns to pull the heat down the the evaporator so it can be cooled. If you are lucky you may be able to adjust your blower up to a higher speed. You may have to even add some more supply airs. Check with your local building inspector. He may be able to give you a list of contractors in your area that would be good for this type of problem. Good luck>>>
Apr 02, 2009 | DeLonghi Pinguino PACL90 Portable Air...
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
I have baseboard heat in my house (hydronic(?) - not electric). The 3 bedrooms upstairs are always 3 VERY different temperatures. My daughter's room is always cold, sons' room is like the Sahara and our...
what it sound like is that your sons room is the closest room to the boiler and is getting too much of the heates water. your room is probebly the room in the middle and your daughters is the last one. Lets start bye taking and shutting down the valves in youe sons room and or adjusting the circuit setters which is what you probebly have . THey should by on the return line and you can adjust them by just closing them down a little bit at a time or if you have a way to take the temperature of the return and the supply lines then you would try to shoot for around 10 delta t. look at the baseboard heaters where the water come in and that should be where you will find the circuit setters. Good Luck and have a Merrry Christmas
Dec 24, 2008 | Heating & Cooling
AC Compressor running outside but no air coming out of inside vents.
Can you say, WOw, Icould've had a v-8 moment! I think you answered your own question or you are not far from the answer. (let me direct you, either the thermostat or the little door on the duct going to your room! Thank-you-very-much!
Aug 01, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
PS3 tv display
It appears that the problem of electromagnetic waves. Somewhere there are a source of radiation that the real problems ps3 and television
Jul 01, 2008 | Sony Playstation 3 (PS3) Console
USA 40GB PS3 - no wireless option on XMB ?
have you checked its manual?
http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
