Question about Nintendo DS Console
Hi after case replacement i cant get bottom touch screen to work
Cant get touch screen after i replaced the case
    Problem Solver:
  • 4 Answers
Is this on a lite or ds you may have damaged one of the connectors on the board i may be able to help with repair email
Posted on Jul 05, 2008
Please help touch stop workin can hear and see calls but cant highlight to touch
You may want to look into replacing the digitizer (screen). You can replace it yourself for around $7.00 (on eBay). Instruction are on YouTube.
Jun 10, 2013 | Televison & Video
Bottom internal touch screen cracked on ds lite-how do we get it repaired
Unless you are comfortable of taking it apart yourself and ordering the part online.
I'd suggest going here.
Mar 03, 2011 | Nintendo DS Lite Console
My touch screen quit working
If the touch screen of your phone keeps working, then it means the sensor board of the phone is bad and need to be replaced, if you can access the menu of the phone, then you need to calibrate the screen first.
To calibrate the screen, you need to go to the menu, then you select settings, then you select calibrate screen then you follow the rest of the instruction from there on.
If calibrating the screen does not help you, then it means you have to fix the sensor board of the phone, if your information from the keypad reaches the screen, then it means you simply need to replace the touch sensor board of the phone.
Hope this helped.
Take care and good luck
Jan 10, 2011 | Samsung SGH-A877 Impression Cell Phone
Phone went dead and now the touch screen wont work. i cant put my access pin in through the keyboard so it wont open. What do I do?
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jun 28, 2010 | Cell Phones
Touch screen not working
   That's the main problem with most of the touch screen.
In case, if it's not working, you need to replace that ( In case, you are sure you haven't played with settings )...
Reset the phone - Factory settings.
In case if the issue would be there, confirmed faulty touch screen. If under warranty, get that exchanged unless buy a new touch screen.
Go for original touch screen setting unless might cause this issue again.
Thanks for using Fixya.
Apr 23, 2009 | ASUS P527 Smartphone
Ds touch screen and main screen not working - connectors broken
if you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash.
Josh Boyer
Jan 22, 2009 | Nintendo DS Lite Console
Replacing bottom screen on a nintendo DS
The bottom screen is not difficult but it does take some care. As noted in another post, the bottom screen is 3 pieces. The actual screen, the touch screen on top, and then a clear plastic cover.
There is a ton of videos and manuals out here that can get you started.
Two things though!! Wear examination gloves when working with the touchscreen. Any fingerprints on the screen and it will not function correctly. I have had a limited amount of success cleaning the screen after my pudgy fingers hit it.
Also, It can be difficult to get all of the screens lined up correctly. Make darn sure you look at the spacing all the way around BEFORE you pull the stack apart. If you do not get it all lined up correctly the case will not fit! (Even then it may take of couple of tries to get it right)
Good luck with it.
May 22, 2008 | Nintendo DS Console
DS Lite touch screen
You'll need a tri-wing screwdriver, a small cross head screwdriver a new touch screen and a lot of patience.
1) Remove the screws from the botom case, 3 tri-wing, 3 cross head and the battery cover and battery.
2) Carefully split the bottom case and remove.
3) Open the clip that clamps the touchscreen cable from the back of the connector with a small screwdriver, just carefully lever up the back edge.
4) Carefully part the botom screen from the touchscreen.
5) Attach the new touchscreen to the bottom screen.
6) Re attach the ribbon cable to the clip.
7) Carefully refit the bottom case taking care not to break the power switch.
8) Re fit the screws.
Mar 01, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
44 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
