My Acer mini desktop power supply not working, no power
  • Hollyecho Montgomery
    Hollyecho Montgomery May 11, 2010
    Sounds like you need to change out the power supply on your computer.
    My question is, does the Power Supply fan come on when you first try to turn it on?
    What else is going on ?
Tks for your reply, not thing on, I think may be fuse, but I don't know where is the fuse... since I change power supply my computer working OK!!!
Posted on Jul 02, 2008
I have an acer aspire 1420-ur10p desk top and it wont power up, no beep light nothing, what do i do...
Check if power cord is working properly.
Check if power supply is working properly.
check if mothernboard is getting proper supply from power supply.
you can also get the cmos battery checked up
Apr 14, 2014 | Acer Aspire Ax1420-Ur10p Desktop PC
Optiplex replace power supply
Hello Jacey,
Below are the system specs for the power supplies that are installed in each chassis of the GX280 system. You can call the Dell Spare Parts
Department at 1-877-717-3355 or click the link below.
Spare Parts Department
Wattage small form-factor computer: 160 W
small desktop computer: 210 W
small mini-tower computer with processor speeds of 3.2 GHz or lower: 250 W
small mini-tower computer with processor speeds of 3.4 GHz or higher: 305 W Heat dissipation small form-factor computer: 546 BTU/hr
small desktop computer: 717 BTU/hr
small mini-tower computer with processor speeds of 3.2 GHz or lower: 853 BTU/hr
small mini-tower computer with processor speeds of 3.4 GHz or higher: 1041 BTU/hr Voltage fixed-voltage power supply-110 V at 50/60 Hz manual selection and auto-sensing power supplies-90 to 135 V at 50/60 Hz; 180 to 265 V at 50/60 Hz; 100 V at 50/60 Hz for Japanese computers
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 23, 2013 | Dell OptiPlex GX280 PC Desktop
Acer Veriton 6900 Desktop says no signal and the screen turns off. The towers power light stays on but the fan isn't running.
Change the power supply and restart your pc. This will happen when the power supply has gone bad. It sends power to low voltage items but not the needed voltage to power the system on.
Good Luck
C2Solutions
Feb 14, 2012 | Acer Veriton 6900 PC Desktop
IWe have replaced the Acer F1 pc power supply with a new one, still no start up power. Power supply does not start, no fan spinning?
Try using a differrent power cable, you could use the cable which goes to the monitor. If that works, then you need to just get a replacement power cable (could be US 3 PIN Spec).
If that doesn't work, then the power supply of the computer tower needs to be replaced.
Oct 25, 2010 | AcerPower F1 PC Desktop
Are PC power supplies generic?
According to Acer's website:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireM5100/AspireM5100sp2.shtml
The computer uses an industry standard 250W power supply so yes as long as you buy one that has all the connectors you need then you'll be fine.
May 14, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
How can I find a replacement power supply for my Acer Aspire X1200 desktop?
you can buy a power supply in ebay or amazon.. remember find the spaficication of the power supply and you can put a generic.. its more cheaper... with the same spec of your machine
http://shop.ebay.com/i.html?_nkw=Desktop+power+supply&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Acer+X1200&_osacat=0
pls click if my solution was helpful
Dec 28, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Source for Acer internal power supply for L320 mini tower
Google it! It's still the best way to line up a number of sites that will let you compare prices of vendors. Keep in mind it'll take a little time to do the research but the savings you realize could be worth it. Admittedly, you'll have to make sure they are in the EU but if you're like me, you'll bookmark a few of your sites and rely on them more frequently. I also add myself to their email list as this usually gets you in on some special deals from time to time. Let me know how that works for you and rate me accordingly.
Jan 09, 2009 | Acer Computers & Internet
Power Supply
Use HP D530 power supply to run SSF desktop which can run on 12v dC current. Just by using one 6000VA in series
Jan 03, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
