Motherboards
Problem for Motherboards
Generic problem for all Motherboards
BOIS
By ajayanmenon on Jul 01, 2008
I have asus cuple-vm acpi MOTHERBOARD . When i check my BIOS setup .. i am seeing the BIOS to be currepted .. i am not able to read the any thing as things seems to be scrabled .. please help actually i need to disvable my on board sound card
Same Problem
Apr 02, 2009
-   I have an Acer TravelMate 2480-2705. I needed to reset the Bios. I unplugged the cmos battery for 24 hours. I plugged the battery in and the laptop would not start. Is there away to rest the motherboard? I pressed the power button. The power light and three other light came on for about two seconds. The fan did not start. When I press the power button I can hear a sound coming from the board. I can hear the sound if I put my ear close to the board. -   2pointo
Apr 02, 2009
Feb 28, 2009
-   Hi,
I have asus A7V400-MX motherboard. When I power PC everything isworking, fans, DVDs HDD is spinning and led is working. You can hearthe HDD hads going back and forth. CPU fan working and black screen.Lights on keyboard are on. But the screen is black-blank I Icleaned CMOS (removed jumper from pin 2&3 then jumped pins 1&2
After that I returned CMOS jumper on default position 2&3 then powered
my PC. Now everything is dead. No fans, no DVDs, HDD...
only light is the motherboard led. I guess I did something stupid. can
you please help me or I have to go and by new motherboard. Thanks, Raduja
-   dzlatanovic
Best Solution
posted on Jul 01, 2008
Helpful)
dileep007
Rank: Guru
Rating: 87%, 1101 votes
if the bios is corrupted then just you can recover it to do this you just have change the bios jumper to the recovery mode ....
to do this refer to the manual of your motherboard it will clearly mentioned ....
to identify the bios jumper you can refer your motherboard manual ...
any doubts you can reply me
i am always here to assist you
thank you
bye .....
dnt forget to rate the solution ...
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS... (More)
Answer
compaq presario mother board, what should I replace it with
Answer
hp pavilion dv9000 motherboard, where is the part number ?
Answer
sir i want to repair my mother bord what i will do
Answer
Installing a NEW ASRock P4i65G motherboard into a Dell Dimension T700r computer chassis. I'm not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in , IL
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
