Question about Lenovo IdeaPad Y510 Notebook
HOW TO PLAY TV ON MY Y510
HOW CAN I PLAY TV CHANNELS ON MY Y510. IS THE CABLE MANDATORY TO BE PLUGGED IN THE SLOT SHOWN UNDER MARKING TV.
vinodvanjani@hotmail.com
  • dktxpert Jul 07, 2008
    How to activate TV programs on my Laptop
  • 479 Answers
Hi
turn on the shuttle center and then do the settings given by chosing reasona and sound stereo.
in last the option of scaning the channels will come and after scaning every time when you will start the shuttle centre tv will be played,
Posted on Feb 04, 2009
I have an LG tv, just got connected to Foxtel IQ they told me to put the red, yellow and white jacks into the input slots. Now do I juist turn on my VCr and follow the prompts or do I need a specific...
When using the RCA jacks as you stated it will be on an input from the tv. You should be able to select the correct input using the remote. Are you going through the vcr first and then the tv? If so you might need to change the channel on the vcr to a selected input as well. Most of these are marked on the back where you plug them into such as input 1,2 3 and so on. On my model I have to select the AV input for the red yellow and white plugs, HDMI inputs are aslo marked the same way. Bottom line is what ever device you have plugged in with the video jacks you will most likely have to select the input your hooked up to unless your recorder senses the signal and automatically selects it for you.
Aug 19, 2011 | Televison & Video
C how can I conect my loptop to the mixer so i can play the music from my computer
To connect your laptop to your mixer, first you need to buy a mini plug to 2-RCA cable, like the one in the figure below:
Then connect the two RCA plugs to one channel, using the inputs marked LINE or CD, as shown by the red arrows in the figure below:
Let us say that you already have two CD units connected to channels 1 and 2. Connect the cable mentioned above to the two RCA jacks of Channel 3.
Now, connect the mini plug to the sound output of your laptop (it should be merked LINE OUT, PHONES or have the symbol of a phone close to it). If the output is dinamically addressed, i.e., the sound driver pops up a windows asking what have you connected to that input, please mark the answer that indicates LINE OUT or HEADPHONES (or something related, but not LINE IN or MICROPHONE).
Adjust your laptop volume to LOW. Switch on your mixer, select the channel you connected the laptop and increase its volume. Put a song in your laptop to play and raise its volume little by little, till you have a good level of sound with no distortion
A word of caution: If you adjust the laptop volume to maximum, distortion could occur, so experiment with the laptop volume to find the best level.
Hope this info may help you!
Apr 01, 2011 | Pioneer DJm500 Professional DJ Mixer...
I can't get video out to TV from Wii video input on receiver. Wii is connected to AV5. Video to TV is thru HDMI out on receiver to HDMI in on TV. I can port the audio but get no video
Hello there,
ok the setup you are using is a Receiver, TV, and Wii unit .
Step 1: plug one HDMI cable into the back of the Receiver unit on slot 2 name on it is called HDMI out jack
if looking at the back of the unit this slot is 2nd from the top left
Step 2: now plug the HDMI cable into the TV this is the cable you just plugged into the Receiver
TV done
Step 3: Wii Setup move the Yellow,White,Red cables over to the right if looking at the back of the unit 2 spots name for this group is called AV out Jacks .
Wii Done
now use the right input channel for this group and you should now See Wii playing .
Thank you and don't forget to Rate
Jan 26, 2011 | Yamaha RXV467 Receiver
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
I have no picture but hear the sound of the system on my tv
It could be 3 things:
Your tv connections are disconnected and need to be replaced. See if anything else works when plugged into these connections.
Your cable cord could have a disconnect internally and the cord needs replaced.
Your graphics card on you XBOX 360 is shot any you need to replace it.
Good luck and please rate my solution accordingly.
V/r,
Coldissickofman
Jan 23, 2010 | Microsoft Xbox 360 Console
What channel do you use for a DVD player? It won't "see" any channels that doesn't have a program on it.
If your dvd player has 3 plugs red white and yellow plug them into the slots marked av. the colors will correspond with whats on your tv inputs. then turn the tv to the av setting according to the av number you have the plugs in either av1 or av2 you should now see dvd player logo.
Jan 06, 2010 | Emerson CR202EM9 TV
Can't play video on the TV
You need to change the "input" source of the TV to match the input where you plugged in the video cable(usually marked yellow) to. The input may be labeled "aux 1" or "aux 2" for example. There is usually a button on the remote to do this or it will be accessible in the TV menu. You should then have your video playing on the TV.
Jul 31, 2009 | Canon DC210 DVD Camcorder
Can't find the channel for my N64
Is your cable RCA, S-Video, or Coaxial? If it's coaxial, check and see if the channel is to 3 or 4. If it's RCA or S-Video, check which slot it's plugged into on your TV. Most likely, the cable's dead, as I've had to replace mine a good 4 times.
Oct 26, 2008 | Nintendo 64 Console
Got a tv and it has a german plug. The plug was changed to a regular one and with an antanea it only plays 2 channels. If hooked up to cable will it play those channels through cable?
I don't see why it wouldn't unless the cable plug on the TV is bad or the circuit that goes to that plug. Get cable and try it or take it to a friends house that has cable and see if it works
Aug 01, 2008 | Televison & Video
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Lenovo IdeaPad Y510 Notebook Logo
134 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
