Install xp on notebook
I can install xp on my notebook i dont have the drivers for sata and i dont no how to do it.
  • Anonymous Jul 08, 2008
    Instale xp y no puedo cambiar a sata en el bios
  • Rogers Balalusesa Jul 14, 2008
    My note book is Toshiba Satellite a205 - s5825 . And the Hard disk is Fujitsu Mhy2120bh ATA device. I can't see it when I want I want to install Windows XP.
This is the tutorial make xp with sata drivers
contain download link
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Posted on Aug 27, 2008
Need help installing a controller
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope this helps
if you physically remove this sata ide card restart your computer then reinstall it this should activate the found new hardware wizard
http://download.cnet.com/windows-promise-sataii150-tx4/3000-18492_4-64684.html
Aug 06, 2011 | BYTECC PCI SATA Card with 1x e-SATA 2x...
Trying to run ms windows xp home install disk. I have the driver for the host controller, but when I try to repair or install new...it said it can not find disk drives. when booting up I can see the two...
Go through the prompts,then have your computers compatability wizard check first.Then look for the drivers properties.Then see if,after it installs the computer still doesn't read the disc then write or call microsoft.Or ask them online about this.
Feb 15, 2010 | Sabrent Serial ATA (SATA) 1 External + 2...
Cannot install xp on my compaq presario cq40-133tu blue screen error may be of sata raid driver
it is not possilble. Try with other XP CD. It will definitely get installed on your PC.
WINDOWS XP REQUIRES MINIMUM OF 128MB OF RAM.
Please do so, your problem will get solved.
Apr 24, 2009 | Compaq Computers & Internet
I have hp g60-243dx and cant install winxp and i try alot of sata drivers.. anyway to install winxp on it?
Yes you can install XP Pro on it. I have with three G60-243dx's.
I'm sure you can on any laptop if one knows how.
joeopis2112@yahoo.com.
Apr 11, 2009 | Computers & Internet
Instal xp pro on sata drive
Either a) get your hands on an XP Pro SP2 CD, b) press F6 to load the proper SATA drivers when prompted (drivers located at: http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFZ283BN&upd_id=2769&os_id=29), or c) build your own bootable XP Pro CD with the SATA drivers already slipstreamed into it by following the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html.
Apr 08, 2009 | Sony Computers & Internet
I have Sony Vaio VGN-CS12GH which is windows vista loaded and i want to change in Windows Xp when i load Windows Xp there is no hard disk controller and i cannot load windows Xp. How to fix my problem,...
Your computer has a SATA hard drive. To install Windows Xp on it, your will have to Press "F6" when you start the installation process (You will get a prompt on the bottom of the screen to press F6 to install third party drivers). During this stage, you will need the SATA drivers on a floppy disk / CD.
To download the drivers, go to the following link.
http://www.sony-asia.com/support/download/284832
Jan 31, 2009 | Adaptec (ASH-1233) (ASH1233) ATA...
Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Aug 09, 2008 | Promise Ultra133 TX2 ATA Controller
Help me to install WinXP in a Gateway Laptop that came with SATA HDD
you have probably already fixed this but maybe others can find this a little helpful. i had to downgrade a gateway ma7 for one of my customers who had lost their recovery cd with vista on it. Their HD had gone bad.
The reason the XP installer says "no HD" is because the the drivers required by the gateways Sata controller (hd controller) are not preloaded on the xp install disc. The only way around this is to download the windows xp compatible sata drivers from gateways website and then slipstream them into a custon windows xp install cd. its actually not as difficult as it sounds. just download the sata driver, a slipstreaming program called nlite.
1 download and install nlite
2 put in your xp install cd, and run nlite, when nlite asks, browse to the i386 folder (your installation files)
3 you will have lots of options to choose from, but for this purpose, choose "add drivers" and select the location of the gateway drivers (c:\cabs\something) i think.
4 finish and burn the cd. then use it to install windows xp.
this little guide isnt step by step, but with a little trial and error you should get by
-Nele, MCSE
Jul 19, 2008 | Computers & Internet
Computers & Internet Logo
1,918 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
