Question about Jenn-Air JFC2089HE French Door Refrigerator
Jenn-Air JFC2070KRS French door bottom freezer model
My Jenn-Air is apparently an older version of the JFC2089HE, but looks exactly the same. I read your solution posted on Fixya on 1/2/07. The freezer works fine, but the refrigerator compartment does not cool. When you refer to removing the panel in the back of the freezer do you mean the panel inside the freezer or the outside bottom panel behind the unit? Thanks, RAS613
  • 237 Answers
The panel on the inside back wall.
Posted on Jul 03, 2008
Jenn air french door water dispenser broken
You have two sides to your 67006531 Dual Water Inlet Valve, so it is very possible the side that controls the water flow for the dispenser is defective. Replace the 67006531 Dual Water Control Valve and I believe your fridge water will work fine.
I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | Jenn-Air JFC2070KRS Bottom Freezer French...
Jenn-Air JFC2070KRS leaks from bottom....why ?????
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 29, 2011 | Jenn-Air JFC2070KRS Bottom Freezer French...
Jenn-air model # JFC2089HES...the freezer door will not open at all..please help
Shut the unit off or unplug it. There's probably ice formed inside preventing the door from opening. Is it frozen shut or can you open it a little? If you can open it a little something may have shifted, if so you may need an expert to come out and take a look
Feb 23, 2011 | Jenn-Air JFC2089HE French Door...
My jenn-air french door refrig is not getting cold
When the refrigerator is not cooling but the freezer compartment is cold, this is usually the result of a defrost problem.
http://refrigeratorheaterrepair.blogspot.com/
Dec 28, 2010 | Jenn-Air JFC2089HE French Door...
Freezer works fine, top not cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Jenn-Air JFC2070KRS Bottom Freezer French...
Refrigerator is warm and freezer is cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 21, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
Water is leaking out the bottom of my brand new Jenn Air French door model JFC 2089 HE. Why?
likely a lot of condensate has been collecting in the catch tray, and it hasn't been able to evaporate off. You may have to slide the fridge out, and empty the tray by hand.
Nov 02, 2009 | Jenn-Air JFC2089HE French Door...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Jenn-Air JFC2089HE French Door Refrigerator Logo
326 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
