FixYa.com
Tags:
GE DCSR483EA Electric Dryer
Element does not turn off.
posted by undecided1 on Jul 01, 2008
During any dryer cycle the element will turn on and remain on. It no longer switches on and off to manage the temperature. If the controls are set to anything with heat, the element will turn on without hitting start. I assume that it must be a thermostat or switch problem however I am told there are two thermostats.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 06, 2008
Not Rated (0)
mikedurland
Rank:Guru Guru
Rating: 89%, 247 votes
  • actually is sounds like the centrifugal switch in the motor is bad.
  • the element should not turn on unless the motor is running.
  • the thermostats are in place to pick up the heat of the airflow, not necessarily the heat directly coming from the element.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dryers problems?
Dryers
hi i am trying to
hi i am trying to replace the... Answer This...
Dryers
I have a Hotpoint VDTOO
I have a Hotpoint VDTOO and I... Answer This...
black streaks
i am getting black streaks on... Answer This...
dryer
Hi, my GE dryer also won't keep... Answer This...
new dryer
buzzer at the end of drying... Answer This...
Repair Service
Find Dryer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
