Question about HP PhotoSmart 7760 InkJet Printer
HP Photo Smart 7760 Printer - red light blinking - printer stuck/froze
My cartridge are stuck to the right with a blinking red light. No text at all on the screen on my 7760 HP Photo Smart. I was printing at the time, last print came out fine, next one would print. I have unplugged the printer from the power and computer to reset it. Still in the same condition.
Any thoughts on a fix? Thank You
  • 1 more comment
  • Sally M
    Sally M Jul 02, 2008
    I have had the same problem with my photo printer. It's still on the desk waiting for a fix. Did you get anywhere with it?
  • Neville McManus Jul 21, 2008
    Yes I have the same probleem .Let me kniw how tio fix it . Moine is HP 7700 Photosmart and the error message reads" CARTRIDGE SERVICE STATION IS STUCK -Press OK "but when I press OK it just gives the same message.
    Anybody out there who can help ...Email me at nevillemcm@vodamail.co.za
    Pensioner
  • Anonymous Nov 26, 2008
    I have the same problem. Stuck proble can anyone fix this?
eagle338
  • 4889 Answers
SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Posted on Oct 27, 2007
mtspace
  • 103 Answers
SOURCE: Hp Photo Smart Printer 7760
When you open the printer control panel, is there a queue of documents waiting to be printed? If so, delete/cancel all documents, check to make sure it is set to use printer offline (in the file menu), and then try printing a test page.
Posted on Dec 15, 2007
SOURCE: HP Deskjet D2360 Printer
i want the printer drivers HP deskjet D2360
Posted on Feb 12, 2008
SOURCE: hp printer deskjet 920c
My HP deskjet 920c won,t stop blinking, eventhough I have changed the
color and black and white carthridge. It will not print.
Posted on Feb 18, 2008
kavala7
  • 5 Answers
SOURCE: print cartridge cradle is stuck
solution for...
" CARTRIDGE SEVICE STATION IS STUCK " with a blinking red light...
it's a bit difficult...just fixed it today....
first of all...u have to be sure that your service station is clear from any other old ink that maybe dried....that stuck the movement of the service station...
if it doesn't work again...folow the next step...
1. u have to pull out the service station... ( the difficult one ..!!! )
2. under the service station, there is a small motor....just find a new one and change it..
it works...
.....i found this new motor in an old hp printer's service station that i have...
thank u
Posted on Jul 25, 2008
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
Print is fading out. some times it is perfect but most print from my HP photo smart 7760 is a portion clear and gradual lightening to smudge like...
Hi Good day!!! Try to clean your print head
Please follow this step:
1. Turn on the computer and monitor. If using a Windows-based computer, click the "Start" button on the toolbar at the bottom of the monitor screen.
2. Move to "Settings," then "Control panel."
3. In "Control panel," look for "Printers and other hardware." Click on it. Inside this dialog box, you should now click on "Printers and faxes."
4. In the "Printers and faxes" dialog box, select the HP printer icon.
5. Using the right mouse button, click on the "HP printer" icon. At the bottom of the list, click on "Properties."
6. You should see seven tabs in this dialog box. To clean the printer heads, click on the "Services" tab. Under this tab, select "Align the printer cartridges" and "Clean the printer cartridges." For now, click on "Clean printer cartridges."
7. A new dialog box should appear, then click on the "Clean" button. The cleaning will now begin for the printer heads. This only takes about two minutes to complete. If you think your printer heads have not be cleaned well enough, do another test until the printer functions as it should.
8. Cleaning printer heads is something that should be done on a regular basis. Cleaning the printer heads will keep the printer from being ruined and causing unnecessary headaches.
Thank you for using FixYa
Please accept if my solution helps you.
Nov 18, 2010 | HP PhotoSmart 7760 InkJet Printer
Blinking red light
Red Light blinks when the ink cartridge is bad..
to check which one is bad..
take out all cartridges from the printer and clean the copper contact and the inner area of the cartridge slot with a lint-free cloth...
power off the printer and unplug the power cable from the printer..
press & hold the power button on the printer for 60 seconds..
connect the power cable and power on the printer..
insert any ONE cartridge and close the door..
similarly insert other cartridges one by one and close the door and check if the light blinks..
if it blinks ..it means the respective cartridge is bad and replace it..
if u have replaced all the cartridge..it might be possible that the cartridge sensor inside the printer have gone bad..
if this is the case so ..u might service the printer..
but I will suggest to go for a new printer as 7660 is quite an lod printer which hp launched in 2004 or 2005..
even if u have juz bought it ..it will be refurbished one..
Aug 12, 2008 | HP PhotoSmart 7660 InkJet Printer
Print cartridge cradle is stuck
solution for...
it works...
thank u
Jul 04, 2008 | HP PhotoSmart 7760 InkJet Printer
Dec 11, 2007 | HP DeskJet F380 All-In-One Printer
Ink cartridge lights blinking
That is happening because you have "smart" chips on your cartridges, so even though you know there is still some ink left in the tank, if the chip says stop, the printer will stop printing. There is a way to bypass that and that is by using a re-setter. You can either buy one or ask to re-set your cartridge in a refill shop.
You can also try holding the "resume" button (triangle in circle for about 10 seconds for each cartridge, sometimes doing that resets the cartridges.
Do not refill the magenta and cyan cartridges if they are not empty, you'll just be wasting your money. Better use it to buy a re-setter ;)
Hope that will help!
Nov 27, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
HP PhotoSmart 7760 InkJet Cartridges Stuck to the RIGHT.
What do you mean by foots sticking the cartridges, is it part of the printer, or the cartridge
Aug 15, 2007 | HP PhotoSmart 7760 InkJet Printer
Error message
hi http://h10032.www1.hp.com/ctg/Manual/bpy21203.pdf good luck
May 03, 2006 | HP PhotoSmart 7760 InkJet Printer
HP PhotoSmart 7760 InkJet Printer Logo
488 people viewed this question
Ben Johnson
