Question about Dishwashers
How can i remove the bloom on glassware caused by the dishwasher. Have already tried all the glass protect stuff available - nothing works for long
We have had the same problem. Here is a solution that has worked.
Turn on the dishwasher with detergent as usual. After the initial drain and fill, stop machine open door and add about 2 cups of white vinegar. Close door and let machine continue cycle. I think you will find that it removes "bloom" on glassware and on the interior of the machine. The trick is to not cancell the cycle but to continue it with the vinegar so that the heat can help the process. J.
Posted on Jul 01, 2008
Deep scratches on glassware and silverware?
What are you using for detergent? Diamonds? I have never heard of water and soap causing scratches in glass and steel.
Apr 21, 2012 | GE Dishwashers
We have a new Frigidaire dishwasher and it does not clean our glasses. They are cloudy and spotted. We run hot water beforehand, have a water softener and still the glassware comes out looking terrible. ...
ok we need to give unit a good rinse out to try and get smaller food stuff out,,,is your jet dry dispenser full ? ,take a regular bowl and put it on top rack face up and run the dishwasher for a few minutes,,the bowl should be full.is your heat dry option turn on...good luck
Sep 10, 2011 | Frigidaire Dishwashers
How did I get the film off my glassware? My glassware has a thick film that is very unappealing. I have to hand wash them. I use cascade detergent.
If you are not using a water softener use a rinse aid such as Jet Dry. This will help to eliminate scum on glassware. Use the solid form of Jet Dry. If you use a water softener you need to decrease the amount of detergent.
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is a hard water deposit and more detergent is likely needed. If the cloudiness is not removed it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. In actuality, dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Mar 12, 2011 | Whirlpool Dishwashers
My glasses are turning white? thank you
This eventually happens to all glasses in dishwashers, especially if they're lead crystal. Only Pyrex and similar types of glass are somewhat resistant to the problem.
The whiteness is usually irreversible: it's caused by a craze of microscopic cracks in the glass surface, effectively etching the glass. There is only one occasional exception and that's where the fogging is caused by microscopic limescale deposits in the cracks when they're still not present in sufficient numbers to cause white fogging on their own. Adding a cup of white vinegar to the final rinse (if your dishwasher allows the door to be opened mid-cycle) usually clears such glasses, but is not a sure thing as those glasses are already damaged to some degree.
There are dishwashing powders/liquids/tablets which claim to be glass-friendly, but all they do is to delay the onset of glass etching. Even commercial glass-washing machines don't completely avoid the problem, but in commercial use glassware rarely lasts long enough to become cloudy.
You only have two sure ways to prevent this being a problem in future:-
1. Never put valued or lead crystal glasses in the dishwasher and to regard all others as replaceable items.
2. Handwash all glasses.
I hope that my speedy answer has met your requirements; please take a moment to rate my response.
Mar 08, 2011 | Siemens Dishwashers
After a complete cycle now have a milky residue
The milky residue on the glasses is not a residue at all: it is irreversible damage to the glass and is caused by a myriad of microscopic cracks in the glass surface combined with surface etching. Vinegar only works if there's a limescale deposit caused by using too little salt (no salt at all, or the salt dispenser set too low, or just not adding supplementary salt in a hard water area when using dishwasher powders with an in-built salt function)
It can happen to most glassware, but will happen very quickly to lead crystal which is why every single dishwasher I've ever sold or rented out says not to put them in the dishwasher. So called "glass protection" dishwasher powders are a marketing gimmick; all they do is to try and eliminate chlorides from the mix and boost the salt content, but they won't actually stop the damage completely.
Similarly, most advise against putting silverware in the dishwasher. By silverware I specifically mean anything made of silver, plated with silver or electroplated nickel silver (EPNS). Stainless steel is fine though. You might like to read this short article on the subject.
Mar 11, 2010 | Dishwashers
Bosch dishwasher she58c leaves all my glasses cloudy
using to much soap will cause this problem.
If the unit can not get all the soap out on the rinse cycle, it will leave residue on the glasses.
ALSO:
1)Make sure you are using rinse-aid!!!!!
2) turn your sink water on before you turn the d/w on. That way the water is already hot when it goes in.
Sep 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Cloudy glasses
Dishwashing detergent will etch fine glassware. Don't wash them in the dishwasher.
Aug 12, 2009 | Dishwashers
Glassware never clean, food particles on glasses
Try running two cups of bleach through your next cycle. This has worked for the resteraunt industry for years.
Aug 09, 2009 | KitchenAid 24 in. KUDM01TJ - Multiple...
Not coming clean
Hi, Are you using Jet Dry Rinse Agent? It is very important to keep the washer supplied with this stuff. Otherwise, glassware will come out with a cloudy film and water spots. If you are using it, perhaps it is not being dispensed by the machine. I am having this trouble now, but my machine is about 10 years old, and has always turned out beautiful glassware unless it ran out of Jet Dry. Now, there seems to be a problem in my machine not dispensing it, and I was searching for a solution when I came across your posting. Baxterdog
Dec 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
499 people viewed this question
Top Dishwashers Experts
