Daily use, some electricity skills, also can make using laptop for we extend, especially for
IBM Thinkpad R60 Laptop Keyboard some of the endurance of large power ", "control effect is notable.
A notebook, LCD display a large screen brightness, reduce power consumption can be very effectively reduced, extend battery time, dark environment does not need higher brightness, we can reduce it. On a keyboard, most of the key combination adjustment screen brightness, "+ F6 / F7" 12.7mm Fn, specific operations can see random instructions.
Second, the lower screen brightness can effectively reduce the consumption of notebooks
Secondly, the screen saver "cancel", also can increase battery life. In his seat to use, the best friend to cancel the screen saver, set to save electricity or the standby mode, according to different operating system, set up different ways in the next section, we will be introduced in detail. The specific operation for cancellation in desktop screen saver, choose empty place use right "properties", and then select "screen saver", "no" directly determine choice.
Three, based on some common port or hardware "blocked", also can be used in mobile save considerable power. As to pull similar PC card, USB, IEEE1394 etc, or any device interface to disable the cd-rom, wireless network and bluetooth devices, can save
Acer ZA3 Laptop Keyboard electricity. Disable hardware equipments, such as common as: drive, right click the "my computer", select "properties", and then select "device manager," in the menu options and find the hardware in the pop-up menu, select "disabled" or "uninstall". For wireless network and the disable bluetooth devices, is accomplished through a shortcut, please see the relevant machine operation manual.
Four, timely monitoring system resources, adjust working condition, reduce process books can also access time, notebook. Through the combination of buttons, "Del + Alt + Ctrl," v process menu, and then to process resource Settings, or operation such as "super rabbit" system, clean, tidy modify system repair operations are not only can also can save energy, space system kill two birds with one stone.
Five
,HP 533549-001 Laptop Keyboard the discharge of battery correctly, can enhance battery features, so as to achieve the ideal power supply. Most of the new laptop computers using standard lithium ion battery, the battery is not so much for the full charge of the operation, but they are still weak memory effects, this in notebook computers use 1 years will become particularly obvious,
especially those in power everyday use of users. The ideal discharge operation, should be every 2 months for a full battery discharge, and take place next wipe and ventilation. It can increase the battery life and maintenance performance.
literally it light if its connected r u fooling me?
My laptop shut down properly 2 nights ago. It is always connected to the wall. It was fully charged when I attempted to turn it on the next night. Does not turn on. Blue lights for plug as well as battery charge, but does not turn on. Any suggestions?
