You need to adjust the bandsaw table square to the blade. There's an adjustment nut under the table top that locks it square to the blade. Also make sure all guides and bearings are correctly adjusting so the blade will not deflect when cutting, but follows a true path. Check to be sure the guides under the table are properly adjusted, as well as those on top, and that the blade is properly tensioned.. It could also be a dull blade at fault, I suppose, if all else is correct.
See these setup instructions.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
