Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer won't drain, makes loud noise
Whirlpool Ultimate Care II washer goes through washing cycle, stops, then makes loud buzzing noise . . . sounds like gears stripped . . . and won't drain, spin or agitate.
  • 3 more comments
  • Anonymous Mar 19, 2014
    washer loud noise
  • Anonymous Mar 20, 2014
    making noise won't spin
  • Anonymous Mar 21, 2014
    The washer was used when I purchased it 3 months go. Please can you help
  • Anonymous Mar 30, 2014
    when I start my cabrio washer is will not sensor it makes a buzzing noise
    will not sensor makes a buzzing sound
  • 3 Answers
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Posted on Jul 05, 2008
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
Wash cycle runs, drains, but will not fill up for rinse cycle
The water inlet valve solenoid needs to be replaced , they are made together.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My ultimate care II washer spin cycle stopped working. The motor makes a loud noise. The agitator no longer turns.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Replace the direct drive coupling between the motor and transmission.
Jun 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer has begun to make a loud buzzing sound when the
This machine has an end-of-cycle buzzer built in. It may be that it just started working.
Dec 31, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
Mar 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
466 people viewed this question
Dan Webster
Dan Webster
Sal De
