Question about Lexmark E250d Laser Printer
Lexmark E250d - have just installed new cartridge & now won't print. ! light & toner light are both steady orange.
    Brigadier General:
  • 10,406 Answers
Define "won't print".
Does your computer show the printer as attached, and "online" or "offline" ?
When you try to print a "test" page, do you get an error-message? Exactly what?
Posted on Dec 15, 2010
SOURCE:
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
The toner and the exclamation lights are steady and i just replaced the toner for thos one E260A11A AND IT DOESN'T PRINT ANYTHING not even the test page please help need to print inmediatly
Press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the newly installed toner cartridge if it is the one suitable for your region.
For further assistance, please call Lexmark Technical Support.
Jun 23, 2011 | Lexmark E260dn Laser Printer
Lexmark e260d printer 4th light orange is continuously flashing. New toner cartridge was installed. Not printing
If the blinking light is on Toner Low (4th light starting from left), press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
May 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
I changed the toner on my Lexmark E250dn and now it has the "!" light on all the time and won't print. It's a new cartridge what is going on?
"!" means error.
Try removing cartridge and installing it again and might be one of the cartridge missing.
Try operating manual. Might helps, there are lots of reason for the error
ftp://ftp.lexmark.com/depot/LXK/E250_Depot_Repair_rev092606.pdf
Suspected
Follow the link on dispute about wrong cartridge due "Toner cartridge region mismatch"
http://www.techsupportforum.com/hardware-support/printer-support/379157-lexmark-e250dn-amp-quot-toner-cartridge-region-mismatch-amp-quot.html
Hope this helps
May 21, 2010 | Lexmark E250dn Laser Printer
The toner light is blinking instead of being on steady
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges.
Also, please follow the appended link to Lexmark's support web site.
Don
http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&productCode=LEXMARK_E120&segment=SUPPORT&question=Toner+Light+keeps+blinking#1
Nov 19, 2009 | Lexmark E120 Laser Printer
Two lights are lit up on the operator panel of my Lexmark E232 printer: a steady blue ready light and a steady yellow toner cartridge light.
Jul 10, 2009 | Lexmark E232 Laser Printer
Lexmark e250dn printer, toner light is flashing, new cartridge
Could be photoconductor at end of life.
You shoul still be able to do a printer test print (press the arrow button).
Look on the printed pagesfor Toner AND Photoconductor.
These show as OK when new or very low count, and 100% when fully used.
If the toner is showing as 100% when you've just replaced it, either the chip is faulty, the wrong one, or if the cartridge is a remanufactured one possibly nor been replaced.
Jan 19, 2009 | Lexmark E250dn Laser Printer
Lexmark E250d
I had the same problem today with my printer. All of a sudden, the first and fourth light lit up. I contacted Lexmark and they said my toner cartrigde needed to be replaced.
The problem is caused by the little chip under the cartridge. I replaced the chip with an old one I had on another cartridge and I got the printer to work again.
You can buy a replacement chip from Lexmark or from a jobber selling replacement cartridge or toner refills.
Hope that helps.
Sep 30, 2008 | Lexmark E250dn Laser Printer
E120 won't print. Orange toner light is on - but the toner is nearly new ...
This problem is caused by an imitated toner............ All you need to do is change it to the old cartridge and see if the light will not be stable. Well the solution i guess is simple............. just go to get a new original toner and it should work well. Hope this helps.
Sep 19, 2008 | Lexmark E120n Laser Printer
Lexmark E250d Laser Printer Logo
336 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
