Sony VAIO VGN-NR220E/S Notebook PC Logo
A
Anonymous Posted on Dec 15, 2010
I have Sony VAIO model PCG-7113L VGN-NR220E a couple adays ago I turn ed on and it freeze before it boot and i turn it off disconecting the battery and the ac adapter and later i try to boot again and it didn't turn on nothing and i con't see thwe sony logo or go to bio setup
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Dec 15, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555162
Points
31058
Take a multi-meter and test the voltage/amperage output of your AC adapter.
If it is OK, then you have a "dead" motherboard.
Is the warranty still valid? If so, then contact Sony, and get it repaired.
If not, contact Sony, and ask if your model is covered by some special warranty,
i.e., if many of your model of Sony have shown the same problem,
then maybe Sony will have addressed this problem.
Otherwise, contact Sony, and see if they can replace the motherboard;
this might be very expensive, if you have to pay for it.
Or, you can remove the disk-drive (which probably has all your files, in good condition),
and and buy a new computer, and connect the old disk-drive as a "slave" drive,
and copy all your files from "old" to "new". Then, you can sell your computer for "parts"
($100 to $200 for the LCD screen, $30 to $50 for the AC adapter, $50 for the CD/DVD),
either on eBay or on Craigs List.
Charles Loder
Level 2:
New Friend:
  • Expert 106 Answers
Charles Loder
Expert
Level 2:
New Friend:
Answers
106
Questions
0
Helped
13087
Points
285
Sorry but it sounds like the computer has crashed and needs to be repaired using the windows system disk
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
3helpful
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
Can I put a T7600 processor in my SONY PCG-7113L
Yes, the two sockets are compatible so you can put the T7600 in your laptop.
Remove the hard drive in a vaio pcg-7112l
Hi kpsmith589...
I could not find your model, but I think this one is close to being the same as your laptop
it is for a Sony Vaio pcg-7113l.
Please take time to rate me
http://www.youtube.com/watch?v=c6u1nY-VOsw
Sony PCG-7113L no display. battery and power light is on...nothing displayed on the laptop screen
The best solution is remove the power and the battery and leave for 5min then connect them and on it . It shoiuild work. PLS REPLY OR COMMENT. THANKS
1helpful
All of a sudden I have no audio on my Sony Vaio VGN-NR220E model, HELP
Take it back to a time before the problem started.
Start > Help and Support > Undo changes to your computer with system restore > restore my computer to an earlier time > Select a date before the problem started.
Please rate my response
VGN-NR220E won't boot up
Bad memory can cause a system to hang as you describe.
If it is accessible, remove the memory cards, swab them with cotton swabs and alcohol and try it again.
Don't put the cards back in while still damp if you use rubbing alcohol.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
