Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Aqualtis AQGD 169 S F12 problem Please help :-(
Hi there, if there is anybody that could help me I would greatly appreciate it. machine is flashing F12 and saying machine blocked. I took the filter out and there was a small coin in there so removed and put machine back together and switched on again. Machine still saying it is blocked and to call assistance!! Do you know if there is anything more I can do before I have to phone assistance? thank you so much.
  • pkirby17 Aug 04, 2008
    Hi. I've got the same problem with it flashing F4 though. No idea how to even get in to check the filter though. Can anyone help?
    thanks
    Paula
  • Anonymous Feb 24, 2009
    same here managed to open the door .there is a yellow lever at the bottom of the machine if you pull it it releases the door lock... mine still blocked ..help
Ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
Posted on Mar 08, 2009
My hotpoint aqualtis is flashing and on sreen says f5
Posted on Apr 17, 2011
Sorry cant help mine too is flashing f5 and i cant open door or anything!!!
Posted on Aug 24, 2008
Dunno but I've got the same with my machine but it's flashing F5 and saying it's blocked.
Posted on Jul 04, 2008
My Aqualtis AQGD 169 S keeps tripping the mains switch
Make sure you are on a dedicated circuit for this machine and that it is a 50 amp circuit. After that you may have a bad breaker switch which is pretty easy to fix. You also cannot rule out that one of your components went bad on your washer.
Feb 28, 2015 | Washing Machines
Ariston aqualtis aqlf9d
PLEASE URGENT!! I have the same washing machine WMW-5812.ER when i press the power on it does not start up why? Please help children getting back to school this week....pleaseee....
Jan 04, 2014 | Washing Machines
Hotpoint aqualtis aqgd169s
It seems most likely shorted somewhere in the wiring system and you have to check for every defective part ,use step by step method
Dec 10, 2013 | AEG Washing Machines
Aqgd 169 wont fill water supply ok
If the other functions are working, then I would suspect the water inlet valve - where your water lines connects to the machine. It is a solenoid controlled valve, that will only let water in during the proper part of the cycle.
Sep 06, 2011 | Washing Machines
My power tripped the other day and when I remade the breaker the washing machine (hotpoint aqualtis aqxxd 169) has come back on but in Polish!!! how do I reset it to English??
(If no one else answers here is how to obtain a manual!)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
May 28, 2011 | Washing Machines
My Hotpoint Aqualtis AQXXD 169 PM is adding time to the was cycle, taking longer to wash through the cycle? ant ideas?
the time is a generic time and will adjust accordingly as goes through programe-for example it allows a certain time to heat in the winter your cold supply may be colder so the machine needs longer to heat water-load size-if its adding more than 30 mins then check filter
Nov 11, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
2,188 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
