Question about Zanussi TC7114W Electric Dryer
Tumble dryer fault
I have zanussi tce 7227w dryer,dryer works fine with no load however when even a small load is in the dryer cuts out then after a minute it will start again before cutting out.the motor does still reverse.is this a motor fault or is there some sort of load cut off sensor?i have some basic electrical knowledge.
  • 550 Answers
Usually this is a sign the felt bearings on the drum, or the roller bearings under the drum are worn and need replacing
felts and rollers should be visible once you open the case
check the rollers turn freely, check the felts are not worn through
replace both rollers or both felts if one is worn
Posted on Aug 28, 2008
Zanussi Tumble Dryer TCE 7276W error code E50 - what shall I do? I put washing in TD and set it A and turned it on, it came up 2.05 as it always does but after some time, I come across "End" is...
Hello this is Dennis from blue hawk electronics I had the same problem with my Zanussi tumble dryer and all I did was to take out he front circuit board and reflow board and has been working fine now for 9 months and still going strong
Sep 03, 2011 | Dryers
I HAVE A ZANUSSI TUMBLE DRYER TC 7103 W, ELEMENT SEEMS FINE, THERMO ALSO FINE BUT STILL NO HOT AIR BEEING CIRCULATED
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 20, 2010 | Zanussi TC7114W Electric Dryer
TCE 7227 W tumbledryer waterconductivity needing regular restting
Carolsquires, I have the same problem with 7227, did you get a solution?
Trevor
Feb 17, 2010 | Zanussi Dryers
My tumble dryer ois not heating ?
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 10, 2010 | Zanussi TC7102W Electric Dryer
Just bought 2nd hand a supposedly good working order zanussi tumble dryer got it home turned it on drum turning but cold air in dryer. we then noticed that the back got rather hot.and then nothing. due to...
this could be the stats or the drum is not turning Common faults -
Jan 10, 2010 | Zanussi TD4112W Electric Dryer
Broken Zanussi tce 7127 w dryer
the dryer is telling you a trouble code like in a car when something is malfunctioning with it, try to call your manufacturer and ask them to tell you what that code means.
Nov 06, 2009 | Dryers
Zanussi tumbledrier TC7103W not heating
Common faults -
Aug 30, 2009 | Zanussi TC7114W Electric Dryer
I have a zwd12270w. Seven second after pressing
The problem is with the tumble drier heating element. If you remove the top of the machine (disconnect it from the electricity supply first!) you will find a big metal oblong "bar" that runs from the front to the rear of the machine. At the rear there are 4 white wires connected to the metal "bar". Make a note of where they go and remove them. You may need pliers to get a good grip of them. Once removed, the washing machine should work just fine but obviously the tumble drier will not. This is a well known fault and it may be worth contacting Zanussi as they MUST know about it!
Jun 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Zanussi TCE 7276 W Condensing Dryer
hi i have a problem with the zanussi 7276w model all lights are on ready to start but the tumble dryer will not start
Sep 21, 2008 | Zanussi TC7114W Electric Dryer
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Zanussi TC7114W Electric Dryer Logo
382 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
