Question about Crown CE1000 2-Channel Amplifier
Electrical prob I appears when i turn it on the 2 fault lights blink along with the clip... heeeeeeelp
  • 1 more comment
  • SHTIFF Jul 07, 2008
    Thanks mate...ill look online for the part
  • valles_rojas Jul 15, 2008
    heeeeeeelp. How I can solve this problem?
  • Anonymous Nov 19, 2008
    When I turn on the the 2 fault lights blinks along with the clipping lamps.
  • 4,234 Answers
This in an indication that there is a problem detected in the final output stage of the amp. This amp will require service. Crown amps are not teh most straightforward designs and should not be repaired by an inexperienced tech. There are high voltages present inside these amps that can be dangerous. The typical cause of this symptom are bad output transistors. Expect a parts cost in the $40 range plus the local labor rate.
Dan
Posted on Jul 07, 2008
Philips PFL7603H not turn on. The white light blinking.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Apr 21, 2017 | Philips Televison & Video
I have a Sony KLD60EX720 tv,it turns on but after 2 seconds it turns off and heads 4 red blinking lights what could be the problem, do I have to change the main board?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Sep 01, 2016 | Sony Televison & Video
?when I turn TV on I get a red light blinks 1 time then 2 times
May 17, 2016 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
I have a Sharp 70" (LC-70LE632U) LED TV. When you turn it on, the front led is on, but no screen. After a few seconds, the front led starts 5 short and 2 longer blink and continue this way constantly.
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 12, 2015 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
Philips 42 PFL7962D do not turn on. The blue light go on and blinking after every 10 second.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 05, 2014 | Televison & Video
Philips dcr pixel plus no picture red light how to fix?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Apr 26, 2014 | Philips Televison & Video
Without any audio source or speakers on output attached, the Crown CH1 Amplifier (as soon as you put the on/off switch to the ON position, the CLIP light blinks a couple times and the FAULT lights blink...
It's very likely that the main power amp section has a faulty part on it that is presumably causing an overload. You should check the devices on the main heat sink of the amp section.
Oct 11, 2013 | Crown CE1000 2-Channel Amplifier
Fault lights keep blinking
I have one upstairs in my repair que. There are some small glass fuses ( 20 mm long) on the power supply board.
Check those
Apr 20, 2010 | Crown CE2000 2-Channel Amplifier
TV will not turn on. FIOS is cable provider and FIOS remote works to turn on the cable box, but TV will not turn on. Red blinking lights code is 5 slow and 3 fast.
Sounds like the TV brand is Philips, of an other brand fitted with Philips mother board inside.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Feb 15, 2018 | Televison & Video
My xs 700 won't stay on
it is worse do you know why it problay be the xs 700
May 03, 2008 | Crown XS700 Amplifier
Crown CE1000 2-Channel Amplifier Logo
439 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
