Question about Minolta magicolor 3100 Laser Printer
Keep getting a dustiness error
Have cleaned area, printing has had some ghousting and now it is worse and printing with fine red lines all over page
  • Minolta Master
  • 6,005 Answers
Replace the magenta drum /image unit as ghosting replace the fuser unit
Posted on Dec 26, 2015
  • 81 Answers
SOURCE: lines across printed page
try to locate the print head of the unit. you will see a mirror there. clean the mirror maybe it has some foreign object.
Posted on Jul 21, 2008
Joed911
  • 4338 Answers
SOURCE: Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 10, 2008
  • 5 Answers
SOURCE: HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Posted on Nov 28, 2008
  • 300 Answers
SOURCE: Printer leaves light red marks on area of page not printed on
This is normally caused by the PC unit (photo conductor unit) you will see four of them sitting on the inside of the front cover if you open it. To check if this is the problem you can swap these around, so swap the magenta with another colour, then print something, if the problem have change to the other colour you will know this is the cause and the unit will need replacing.
Hope this helps
Posted on Apr 19, 2009
  • 32 Answers
SOURCE: AUTOMATIC FEEDER LEAVING LINE ON SCANNED PRINT-OUT
clean the thin DF glass strip on the left side with a damp cloth
Posted on Mar 18, 2010
Error Number : 1003 No paper. Load the paper in the cassette correctly and press the OK button on the printer. Plain paper of A4, Letter, B5, and A5 sizes will be fed from the cassette because...
Another possible reason for getting this error is a dusty printer. I don't dust very often so dust piles on everything, including my printer. My daughter wanted me to print something for her and the first page went through just fine. But the second never started and I got error 1003. I had plenty of paper loaded and my settings for the size of paper were correct. I dusted out my printer and everything else printed just fine. My theory is the top paper had dust bunnies on it that were pulled into the printer when it pulled the first page in. Maybe the dust got caught on a sensor that told the computer there wasn't any paper. Regardless of what happened, a quick cleaning fixed the problem. I just wanted to throw in my two cents for anyone out there that may have a dusty printer and run into this error.
Sep 08, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
Hello - my Brother DCP 330C printer is printing horizontal faded lines on both color and Black and white copies. I have changed the toner in all areas but still no change. Could the problem be with the...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
My Brother HL1230 printer prints with whole lines of text missing several times on a page and gets worse by missing more lines if printing several pages. It has a new toner cartridge. How can I sort this...
Good Luck
RK
Jan 28, 2010 | Brother HL 1230 Laser Printer
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
HP Laser P3005dn having paper jams more and more
if it gets a lot of use and the pickup rollers has not been changed, i would start by that and keep cleaning it sinse dust gets on it and makes it slippery.....to clean either run a test page or print something and use a moistened rag so the roller cleans itself as it rotates (of course remove the paper cassette)
Jun 23, 2009 | HP LaserJet P3005 Printer
Fine Coloured streaks on printed page
The most common problem is the photo conductor unit. What ever color the line is change that unit. The Photoconductors are a customer repalcment item.
Jun 04, 2009 | Ricoh Aficio SP-C210SF Printer
I just picked up a 4500n hp laserjet, and it was very dusty inside and out. So I cleaned it inside and out very thourougly. I plugged it in and print the configuration page, the plc, ps fonts, demo page 1...
Most likely the drum is failing. After printing pages remove the drum and see if it has streak on it to be sure (don't bother trying to clean it - if it has streaks the cleaning mechanism has failed)
Mar 22, 2009 | HP Color LaserJet 4500n Printer
Ricoh aficio 1515f printing dark line down left side
If the print can be rubbed off then this suggests the fuser unit is not working correctly. It could be that the thermistor is covered with toner and making the machine think the fuser is hot enough when it's not.
The black line could also be caused by the fuser if one of the pick off fingers is coated with toner or has worn into the Teflon of the roller.
Does the machine show the lines when you print a page from memory - such as a counter or config page? If not, this would suggest the optical path is dirty. Try cleaning the glass and look at the mirrors inside the scanner to see if they are dirty/dusty.
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Minolta magicolor 3100 Laser Printer Logo
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
