Question about Motorola Mobility RAZR V3
Having trouble paring blueant z9 to razr
I cant sem to connect bluetooth to phone when looking for device says no device found
    Genius:
  • 1,019 Answers
Usually you,ll have the bluetooth device, close to the Phone. And while the phones searching for the device. Power it On/Off turn the volume up and down If Applicable. the phone is trying to find a signal from the bluetooth device to enable it to communicate. by pressing various buttons your sending the signals from the bluetooth to phone.
once the phone finds the signals, it will set it up to communicate ( Pair-Up )
Mike @ Compurepair.
Posted on Jul 01, 2008
Cannot pair my iphone with blueant
The typical setup with a Bluetooth is press whatever the main button on the device is until there is a glowing blue light (usually about 3-6 seconds). You then need to go to the Bluetooth menu on the phone (under settings). Select scan for devices. After a few seconds, you should see Blueant Z9. Select it. it will then ask for pin to pair device. It should be either 0000 or 1234. After that, you should be all done.
May 04, 2011 | Blueant Z9 Wireless Headset
Im trying to pair my iphone with my blueant but it keeps saying (make sure blueant st3 is turned on in range and ready to pair)
First off the device you are referring to is a ST3 and not a Z9. What you need to do is put the device into pair mode prior to searching in your iphones bluetooth menu, to do this with the device off hold down the green button until you hear a language loop. When you hear the language of your choice let go of the green button and press it once right away. You will hear a message about your phones bluetooth menu, when you hear that go to your Iphones bluetooth menu and select the ST3 and it should work.
Regards,
Rylan
Dec 04, 2010 | Blueant Z9 Wireless Headset
My iPhone wont recognize my Z9 Bluetooth (blueant) headset
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
May 20, 2009 | Apple iPhone Smartphone
My bluetooth wont connect to my phone. ive connected it b4. you jus hold dwn the button until it flashes a few times to pair but its not workin. knw where i can find a users manual on line?
I GOT THE ANSWER FROM ANOTHER Z9 ISSUE RAISED BY SOMEONE.
HOLD THE RED BUTTON FOR A WHILE WHILE KEEPING THE NEW DEVICE IN BLUE TOOTH SEARCH MODE. THE BLUE LIGHT IN BA STAYS STEADY AND TELEPHONE DEVICE PICKED UP THE SIGNAL . PAIRING WAS DONE AS DIRECTED BY PHONE DEVICE.
Apr 28, 2009 | Blueant Z9 Wireless Headset
I cannot remember how to pair BlueAnt bluetooth to new devices
You will need to set the Z9 into pairing mode before your iPhone will find it.
The manual for the z9 is here
With the Z9 OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start flashing. The Z9 is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
Enter Passkey "0000" when your phone prompts you. The phone and Z9 will now Pair.
Mar 10, 2009 | Blueant Z9 Wireless Headset
I am trying to pair my z9 with my nokia n95
  1. Delete the old Z9 pairing
  2. With the Z9 OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start flashing. The Z9 is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes
  3. Enter Passkey "0000" when your phone prompts you. The phone and Z9 will now Pair
I hope that helped.
Feb 28, 2009 | Blueant Z9 Wireless Headset
Pairing z9
Pairing Procedure
This is an example only and may differ from your phone, but the process will be the same.
Perform a Bluetooth device discovery on your mobile phone to add a new device.
Jan 29, 2009 | Blueant Z9 Wireless Headset
Problem Pairing Blackberry 8700 w/ BlueAnt Z9 Bluetooth Headset
This problem has been solved by turning on the blue ant system then holding down the vol - and vol + buttons simultaneously for 5 secs.
Dec 15, 2008 | RIM BlackBerry 8700c Cellular Phone
Pairing Problem with Cell Phone and Bluetooth earpiece
Not all bluetooth headsets are compatible. These are:
BlueAnt Wireless X3 micro Bluetooth Headset.
BlueAnt Wireless V12 LCD Bluetooth Headset.
BlueAnt Wireless Z9 Bluetooth Headset.
http://www.yourwirelesssource.com/buy/accessories/cat/28/model/1005_300368/accessory/291758?source=google_base
Mar 28, 2008 | Cell Phones
Motorola Mobility RAZR V3 Logo
94 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
