Technics amplifier sound cuts after a few seconds operation
  • 01494 May 08, 2009
    everytime i turn it on it cuts out after a few seconds and the red light remains as it is on stand by
    Sergeant:
    Champion:
  • 417 Answers
SOUNDS LIKE YOUR OVER LOADING
OR YOU HAVE 1 WIRE SPEAKER WIRE AROUND THE WRONG WAY
Posted on Jul 03, 2008
    Master:
  • 726 Answers
Hi there if the sound cuts out after a few seconds and then if you turn it back on again if it does the same you might have a few problems ,,
make sure you are not overloading with to many speakers
make sure all positives are to positive and negatives are to negatives
make sure the unit is not over heating or getting to hot make sure it has room to circulate the hot air
and also check the wiring for any breaks or rips that could be touching each other to make it shutdown
when it cuts out its going into safe mode to prevent further damage one of those will defintly be your problem good luck with it hope this helps
Posted on Jul 01, 2008
What causes the sound to cut for a few seconds?
Hi i just would to know if you did try to connect your TV by HDMI to test if your optical output of your reciever/amplifier have some problem. In second time yes maybe you can have an overheating problem, just take a look at your grid and maybe a clean-up will be necessary. I don't think your amplifier have a fan.
Don't hesitate to contact me here in this post. have a nice day.
Nov 10, 2014 | Technics SA-DX750 Receiver
Can i hook this amp to my home sound system
Technically, yes, but there are some challenges. First, the input voltage to the amp is 12VDC, not 120VAC. You would need to find a power supply large enough to supply 12VDC at 30-40 amps (plus has proper currently limiting or fuses to protect against overloading). Second, most home speakers are 8 ohm impedance. While the amp can power an 8 ohm speaker, the output power is cut in half (compared to a 4 ohm speaker).
Jan 14, 2014 | Audiovox Rampage 1200 Watt Amplifier Car...
Hi, my SU X120 Technics amp cuts out after a few seconds of operation, I think it is a protection that has been activated. Any solutions will be appreciated. Thanks, Igi
Sounds like an amp draw problem .check make sure all connections are ok and nothing is touching.Check sub connections are not touching in any way..Hve u done the big 3,how do u have your gain set on amp if it was to hi it will do this also..its not a volume.its to match to you head unit with a multi meter.
Aug 25, 2009 | Audio Players & Recorders
Technics amplifier su-v98, cuts off at 22-24 desibls
The most common cause of this is defective coupling caps inside. These allow some DC voltage to pass through to the final amp stage. This DDC voltage is detected by the protection circuit and the unit shuts down. This unit will require service. Please note that this should be a simple and inexpensive repair. The cost should be less than $10 for parts.
Dan
Jul 04, 2009 | Technics SUV500 2-Channel Amplifier
Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Apr 13, 2009 | Technics SA-AX530 Receiver
Sound cutting out
protection circuit cutting in. needs a tech shop visit not something that can be done by unqualified persons
Apr 05, 2009 | Audio Players & Recorders
Sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Mar 14, 2008 | Technics SUV500 2-Channel Amplifier
Sherwood Amplfier
Sounds like you like your music like me... LOUD. If you've done this a number of times, there are a few things that can happen:
1. You've blown the speakers... but you've said it operates for 2 seconds, then cuts out.
2. You've damaged the amplifier modules within the amp and they immediately overheat upon power-up. Does the music come back like 5 or 10 seconds after the unit cuts out?
3. Thermal switch has malfunctioned and just cuts off the power to the amplifier modules as soon as it sees any heat.
4. If you've gotten the amp really HOT during playing, it's possible that it's as simple as the amp modules are only intermittently connected (fatigued/stressed or cold solder joints) at the on the PCB. Just resolder the connections of the amp module to the PCB. I've seen that happen numerous times and that's where I'd place my money.
Jan 02, 2008 | Audio Players & Recorders
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
190 people viewed this question
 Grubhead
Grubhead
