Question about Canon Office Equipment & Supplies
Canon ir1610f will receive fax's but will not transmit, is there anything i can try / do?
  • scott34 Jul 01, 2008
    cheers, nothing wrong with line / cable. obviously fax board issue
    cheers for help
  • 134 Answers
Try to use your telephone line to fax out(assuming it is an analog line), once you eliminate the phone line being the issue, you can try different numbers to fax to and make sure it is not just one number. Otherwise it could be an internal telephone board issue.
Posted on Jul 01, 2008
Canon MX850 won't transmit faxes.
maybe there is no response on the other side, try to send fax to another number
Oct 29, 2014 | Canon PIXMA MX850 Multifunction Printer
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
UNABLE TO PRINT RECEIVED FAX
Hello mate,
you have to replace Paper Feed Assembly (including paper sensor).
Unfortunately i'm not pretty sure you'll be able to find new spare parts....
Good Luck!
Apr 26, 2010 | Canon FAXB160 Plain Paper Bubblejet Fax
Fax will receive but not send..
Fax machines have transmitters and receivers. It sounds like the transmitting is bad ( it is a board). I am assuming that you were able to send ( transmit) faxes before and this just started? I also assume that you have not moved the phone lines? If you have moved the phone line you may just have it plugged in wrong. If you have not moved and it was able to send before then I would say you need to have the transmitter board replaced. Replaced because it would be cheaper then sending it out for board repair. But if you call a Tech out to look at it, find out what they will charge you for the board with labor -- it maybe cheaper to buy a new one.
Jan 01, 2009 | Office Equipment & Supplies
Canon won't send or receive fax
hii,
mikeortho659...for u information u fax modem of this mp530 faulty(the place u connect phone line through rhe machine)..that why either fax or receive not working..
Oct 29, 2008 | Canon PIXMA® MP530 All-In-One Printer
Canon FAX-JX200 Problem
Make sure that the line coming from the wall is plugged into the "L" port on the machine. The port with the icon of a telephone over it is for an extension phone, answering machine, computer modem, etc.
Apr 15, 2008 | Canon FAX-JX200
Can not transmit faxes
do you have a seperate fax line? if so check the fax line.
also in the fax menu set up your fax to phone/fax mode, and set up all your fax info.
if you have distinq ring you need to set up your # of rings.
Feb 22, 2008 | Canon FAXPHONE L170 Plain Paper Laser
How to change the receiving tray for faxes?
Look around for a small lever or lock that you adjust for one way or the other. open the top front and look to the left. it might be there.
Feb 12, 2008 | Canon FAX-L200 Plain Paper Laser
old marine
old marine
