Problem of C25 risograph cr 1610
I TRY TO FIT MASTER REMOVAL SENSOR BUT PROBLEM STILL PERSIST
  • dkingry Feb 26, 2009
    I am looking for a riso cr1610 drum
  • 76 Answers
Remove the old mater on drum and clean your master incoder strip and sensor. Look also at your drum clamp and bend the 2 sides of the 2 arms a bit up that goes under the clamp unit so that it can open a bit wider. let me know if you still struggling.
Posted on Oct 08, 2009
My bizhub c25 waste toner was full so replaced and will not now reset.
The C25 stores toner in a waste toner container. On the front of that container there is rectangular clear window that fits into a sensor when installed into machine. The sensor passes a beam of light through that window. When the bottle is full there is toner inside that clear plastic window which stops the light from making it through the window and the machine will tell you the waste toner is full. Just dumping the container out will not clear that window and by putting it back in the machine you will get the same toner full message. If you are going to try to reuse that container you will have remove the black plastic cover that is glued to the container above the clear plastic. Then use something like a Qtip to clean all the toner off of that clear window(much easier and faster to just replace in with a new container). if you still get the waste toner full message after you install it then remove it and wipe off the sensor that the clear window sits in. This will clear the message and you can continue your copy job.
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
Error A-01-211. Master roll not feeding properly.
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
OR replace it
Feb 22, 2013 | Riso RZ220 Duplicator
Error code A-01 -201
Which model of Risograph?
Error type A01: Master mis-feedError point 201: Master-positioning sensor does not go to ON even after the write pulse motor is activated durcing the paster-positioning, master cut, or master-loading operation.
Try this:1) Pull out mastermaking unit and rewind master roll, then re-set master in place.2) Check write pulse motor and its gear
Sep 18, 2012 | Riso Office Equipment & Supplies
RISOGRAPH (RISO) - Service-Manual
my Risograph CR-1630 AW, error 5. what can i do?
Jul 29, 2010 | Computers & Internet
Error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Feb 13, 2010 | Sharp AL 1631 Copier
RISOGRAPH CR 1610
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 25, 2009 | Riso RZ220 Duplicator
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Risograph CR 1610
Risograph C1610 Error E 78 - Problem was fixed by re attaching the detached cable inside the top scanner. you have to take apart the scanner on top and re attache the cable and that should get rid of the error
Aug 06, 2008 | Office Equipment & Supplies
631 people viewed this question
jasbo
jasbo
