Question about HP Color LaserJet 2600n Printer
Paper jam I have a paper jam in the rollers at the top of my HP Laserjet 2600n. how can I get to it?
  • bil_anshu Jul 02, 2008
    paper jam
  • jorges123 Jul 22, 2008
    same problem...
  • 89 Answers
The paper jams are in the fuser area. Which is very hot. The following is a link to change the fuser. It may be that you can get to the jam by removing the top cover.
http://www.laserpros.com/pdf/HP%202600-2605%20fuser-etb.pdf
Posted on Aug 03, 2008
PAPER JAM - HOW DO I REMOVE SHEET OF JAMMED PAPER
The 2600s have a door in the back that can be removed to gain access to any sheets that may have become jammed. The front panel opens in two stages, the second requiring a button press on the side to gain access. Using gentle pressure and left-to-right motions you can slowly pry the trapped page from the rollers (make sure the printer is off before you begin) Some amount of disassembly may be required if the page becomes torn, but refrain from using sharp objects to pry the paper free. If you are unable to find the jammed sheet, remove the paper drawer and check the feed rollers.
Nov 25, 2010 | HP Color LaserJet 2600n Printer
My printer has the problem of pepar jam
if the printer says its jamming and there is no paper jam.. change the pickup rollers.
if there is a jammed piece of paper then more info would help.
-printer name / model / make ?
-exactly where it is jamming (paper tray, inside the printer when you open it up.?
Jul 21, 2010 | HP Color LaserJet 2600n Printer
How can i repair my hp laser jet 2600n printer when paper jam
Hi. I would suggest cleaning your printer on the inside and removing any blockage from rollers or look for any peace of paper that's clogging any device inside your printer. Also try pressing all the sensors inside to check if they are not stuck or something. Hope this helps
Jun 04, 2010 | HP Color LaserJet 2600n Printer
HP 2600n Ironing transfer paper jammed around top roller
It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
Jun 05, 2009 | HP Color LaserJet 2600n Printer
Paper Jam in HP2600n printer
Very difficult to disassemble. You should call a HP Service Center.
Jan 22, 2009 | HP Color LaserJet 2600n Printer
How to clear paper jam in output bin
The printed page comes through the hot fuser at the top of the printer, through the exit rollers an end up in the exit bin.
We cleared a massive paper jam out of the fuser, by removing the grey surround on top of the printer. The plastic hooks that hold it in place get broken in the process, then you will the jammed paper between the fuser rollers, and the exit rollers. A technician can do it for you, but is unessersarly costly.
Dec 21, 2008 | HP Color LaserJet 2600n Printer
Paper jam
That part is the fuser unit and is hot if the printer is on. Here are instructions for you. Good Luck!
Jul 27, 2008 | HP Color LaserJet 2600n Printer
Says paper jam, no paper inside
If you are getting a paper jam error, but no paper inside- Check your Pick Up rollers in the paper tray and then check for any stuck flags in the printer.
Sep 20, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
554 people viewed this question
Seeker5211
Seeker5211
