Question about GE Washing Machines
Excessive vibrations I have GE Adora washer and dryer stacked in my second floor laundry room (floor is reinforced). The machines are balanced yet when the spin cycle starts the vibrations are shaking the house apart. I've addressed the obvious so what's the next step.
  • Anonymous Mar 22, 2014
    How do you attach the top panel? I recently renovated my laundry room and no longer need to stack my washer and dryer. However, after purchasing the recommended parts and top panel. I cannot find any instructions on how to actually attach the panel.
I have ordered KE shake away pads. I'll have to see how they work.
Posted on Jul 05, 2008
Recently moved our laundry room from 1st to 2nd floor, not realizing that front load washers are not good for the 2nd floor...
look the really heavy duty floor pads used in horse stables very dense and thicker than anti vib because even it restacked extra weight wont stop the vibration
Jul 27, 2016 | LG Washing Machines
Tip
Front Loader Excessive Vibration
When the manufacturers first introduced the front load washers, they did not take into consideration the possible problems created by the centrifugal force of the washer's spinning action. Most of these washers spin in excess of 1200 rpms! A spinning action that fast, coupled with the washers heavy weight and a floor that flexes (even a little) will cause a resonant vibration. In simple terms, it will cause the washer to bounce or walk.
Some of the early manufactured shock absorbers, weren't up to par and were uable to maintain the washer suspension over continuous use. The manufacturer's improved the shock absorbers to make them more stiff and minimize vibration. Replacing the shocks with heavier duty shocks does help, but if the flooring is not substantial enough the washer will continue to have problems.
If the washer is mounted on a pedestal, this can make the problem worse. Early model pedestals had an open back which caused it to "tin can" when the washer spun. "Tin-canning" is the phenomenon of the sides of the pedestal casing waffling in and out as the weight of the washer rides on top of it. This would also cause excessive vibration. The solution: The manufacturers redesigned the pedestals with an enclosed back that would prevent this from happening. If your washer is a later model, you should have an enclosed back on the pedestal. If there is no back panel, a stiffiner kit can be purchased and installed by any Do-It-Yourselfer. All you need is a drill and a screwdriver. Instructions are included. The part number is 134682000. I found it listed at searspartsdirect.com.
Check the leveling of the washer. You need to adjust the feet of the washer ensure it is level front-to-back and side-to-side. The feet are adjusted using a wrench to turn the legs up or down. Use a level to check your work. Once completed, you should be able to place your hands diagonally across opposite corners of the washer top and see if the washer moves at all. If unlevel (just the slightest) the washer will vibrate during the spin cycle. If the washer is mounted on a pedestal, you level the feet of the pedestal, NOT the washer. Make sure the washer is firmly mounted to the pedstal fisrt. Then, level the feet of the pedestal using the same procedures outlined before.
Another cheap method to get rid of vibration is to use foam padding to sandwich between the sides of the washer, the dryer and the wall. Swimming pool noodle foam works real well and is very inexpensive. About $3 or $4.
Overloading the washer with heavy items can cause excessive vibration due to an unbalanced load. If you load items so full that you can barely close the door, the load will have a hard time distributing evenly around the perimeter of the wash tub. Once wet, and the tub begins to tumble, the load becomes entangled and will pack on one side of the tub. This will cause the washer to jump and walk across the floor on the spin cycle. This can also cause premature wear to the door bellow, damage to the door latch and damage to the shock supports and counter-weights. Always follow the manufacturer's wash load recommendations as outlined in your owner's manual.
Now...when you've checked every other possibility, its simply not the washer. Most consumers don't like to hear this (especially owner's of newer homes). The worst places you can put a front loading washing machine is in a mobile home, or an upstairs laundry room. The floors in these areas are usually not as reinforced. Even homes with a laundry room over a crawl space or basement can sometimes have problems if the floor flexes. Most home builders don't take added reinforcement into consideration for the installation of a front loading washer.
An inexpensive way to reinforce a laundry room floor is to install a 4 x 8 sheet of heavy plywood under the washer. The plywood has to be a minimum of 3/4 inches thick and needs to be secured (screwed down) to the existing floor. This distributes the weight of the washer better. You can also safely fit BOTH the washer and dryer on top of it. A lot of people don't like this idea, because they feel it wrecks the look of the existing floor. I have seen homeowners, install a reinforcement this way and add paint, trim molding, and even tile to give it that "supposed to be there" look.
You may get mixed reviews about this, but I have seen it work for homeowners. Plus, its a less expensive option than hiring a contractor to firm up your sub-flooring or joists.
I hope you find this information informative and helpful. If you have questions, please let me know.
on Dec 13, 2009 | Washing Machines
Stacking washer and dryer still vibrating and walking during spin cycle even though stacking kit is attached
Assuming that you've installed the stack kit according to instructions, you should check the following:
1. The dryer should be securely attached to the washer and not wiggle or move. The washer must always go on the bottom of the stack.
2. Washer should be level and have all four level legs making solid contact with the floor, no wobbling.
3. Make sure the drain hose is not pinched or restricted (or there is not debris in the drain pump) as a slow pump out will accentuate vibration problems.
4. Make certain you've removed all of the washer packing bolts before using the machine (see owners manual for description.)
5. The floor must be solid with no "springy" or "spongy" feel. No matter what you do to the laundry set it will vibrate on a less than solid floor. This occurs on upstairs installations or other wooden floors, especially in an older home. Sometime the floor can be braced to stiffen it. Also, vibration pads are sold that might help minimize the vibration. The walking is a symptom of vibration.
Experience shows that most problems of this sort result from incorrect installation and/or flooring issues, not the laundry. You should not attach it to the wall. It is possible the washer has a problem in which case a technician would need to check the unit. They can check the suspension and drive system for proper operation.
Aug 24, 2014 | Samsung Front-Load Washer and Dryer stack...
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Walking Washer on pedestral
The recommendation by the service tech is actually a very common and very effective solution to your problem. I'm sure it was explained to you, but for the interest of anyone else reading this, I'll explain it again.
When the manufacturers first introduced the front load washers, they did not take into consideration the possible problems created by the centrifugal force of the washer's spinning action. Most of these washers spin in excess of 1200 rpms! A spinning action that fast, coupled with the washers heavy weight and a floor that flexes (even a little) will cause a resonant vibration. In simple terms, it will cause the washer to bounce or walk. Replacing the shocks with heavier duty shocks does help, but if the flooring is not substantial enough the washer will continue to have problems.
Another cause could be your pedestal. Early model pedestals had an open back which caused it to "tin can" when the washer spun. "Tin-canning" is the phenomenon of the sides of the pedestal casing waffling in and out as the weight of the washer rides on top of it. This would also cause excessive vibration. The solution: The manufacturers redesigned the pedestals with an enclosed back that would prevent this from happening (You would think they would have figured this stuff out during testing phase of manufacturing, huh?) If your washer is a later model, you will have an enclosed back on the pedestal. If there is no back panel, a stiffiner kit can be purchased and installed by yourself. All you need is a drill and a screwdriver. Instructions are included. The part number is 134682000. I found it listed at searspartsdirect.com.
Yet another possibility is the leveling of the machine. Since yours is mounted on top of a pedestal, you need to make sure you are leveling the feet of the pedestal, not the washer. If the washer is properly mounted, it is bolted to the top of the pedestal frame. You should then adjust the feet of the pedestal to ensure it level front-to-back and side-to-side.
Now...when you've checked every other possibility, its simply not the washer. Most consumers don't like to hear this (especially owner's of newer homes). The worst places you can put a front loading washing machine is in a mobile home, or an upstairs laundry room. The reason - the floors are usually not as reinforced. Even homes with a laundry room over a crawl space or basement can sometimes have problems if the floor flexes. Most home builders don't take added reinforcement into consideration for the installation of a front loading washer.
I told you ALL of this information to finally get to this point. An inexpensive way to reinforce a laundry room floor is to install a 4 x 8 sheet of heavy plywood under the washer. The plywood has to be a minimum of 3/4 inches thick and needs to be secured (screwed down) to the existing floor. This distributes the weight of the washer better. You can also safely fit BOTH the washer and dryer on top of it. A lot of people don't like this idea, because they feel it wrecks the look of the existing floor. I have seen homeowners, install a reinforcement this way and add paint and trim molding to give it that "supposed to be there" look.
NOTE: This problem will apply to any front loader with floor reinforcement issues no matter what the brand name is.
May 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Balancing problem Frigidaire stackable front load washer/dryer
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2009 | Kenmore 98702 Stacked Washer/Dryer
Maytag Epic Z
heres a product that might be helpful http://www.apwagner.com/index.php?main_page=product_info&products_id=148095 really had good results with this since inroducd a year ago, $ 30 bucks its worth a shot!!!!
Oct 17, 2008 | Washing Machines
My husband and I are building a new home with a second floor laundry room. We are very interested in purchasing a LG washer (WM2688HWMA) and dryer (DLEX8377WM), but need strategies to keep the units...
hi As a safety device, a dryer usually has a door switch that activates the working .A dryer is simply a large drum into which wet laundry is loaded. A motor with pulleys -- connected by a series of belts -- turns the drum. Air heated by a gas heater or electric heating element is blown through the drum to dry the laundry. The temperature and speed of the drum are controlled by a series of thermostats operated from a timer device on the control panel of the dryer.
The control panels on the latest dishwashers can look intimidating. They're loaded with so many dials, push buttons, and other features that the machine looks too complex to repair. This is actually not the case. With the exception of the control panel, dishwashers haven't changed much in basic design over the last two decades.
Sep 12, 2008 | LG Washing Machines
MILDEW
if you think it vibrates now wait till you stack it more pressure downward on the floor will cause more viberation
May 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer LSQ9659pw4, very excessive vibration and walking
hello im proably the only one that will jump on this how old is this unit
Mar 29, 2008 | Washing Machines
Washing Machines Logo
213 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
