E007 send me how can i remove this error
  • 287 Answers
What brand copier do you have please? Xerox, Kodak,Canon,Ricoh,Savin,Gestetner,Nashua,Lanier,Mita,Panasonic,Sharp,Brother,Pitney Bose,Imagistics,Royal,IBM,Sharp,Toshiba,Kyocera,Konica, Minolta, to name a few. This error code means completely different problems for each manufacturer. It might mean the difference between $ 2.00 and $ 2000. Recommending a $2000 circuit board when all you needed a $2.00 fuse might be a bit on the overkill side.
Posted on Jul 03, 2008
Solution to solve system Error E007 on IR 2016i copy machine
Was the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error.
error codad E007 First make sure fuser plastic not damage? Or not move the proper place? if damage fuser plastic Replace by new one if the fuser plastic not damage keep proper place.
fixing fuser film is worn out or broken remove the fixing unit ang check the fuser film if its worn out broken replace a new one .
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Canon CLC 1140 Copier
System error E007
Error E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condition of your Film also check the green handle in this area for paper jam removal. if it is broken or removed, it can cause this error.
Regards
Nov 22, 2010 | Canon iR 2016i Black and White Copier
System error E007 IR2016 photo copier
i think the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. Good luck sir let us know how you make out.
May 18, 2010 | Computers & Internet
Hi,I have the problem with canon IR2016 ''system error E007'' Please help me by sending your best solution to solve this problem. thanks
Oct 28, 2009 | Canon Office Equipment & Supplies
I have System error E007 problem in my Canon iR-2016 copier machine?
Hi
Thanks for using FixYa. Error E007 means there is a jam in the Fixing/Fuser Assy. Error E007 is related to a non-detection of the Fixing Film/Upper Roller, the fixing film sensor didn’t detected the rotation of the film for 6 sec or more while the fixing motor is driven. Please check the condition of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. If everything is fine then try clearing the error by entering the service mode, you can do it by pressing *(star), then press 2 and 8 keys at the same time & then press *(star) again.
Now press COPIER>FUNCTION>CLEAR>ERR, to clear the error code.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 28, 2009 | Sharp AR-M350N Copier
Error E007
 I  HAVE PROBLEM IN CANNON COPIER IR 2016, ERROR CODE E007. KINDLY HELP ME TO SOLVE THIS PROBLEM
Jan 21, 2009 | Office Equipment & Supplies
SYSTEM ERROR - E007 SOLUTION 3
when i switch on the machine, it show a red light with the word system error E007
Aug 09, 2008 | Creative Labs Zen Nano Plus MP3 Player
System error e007 for canon copier ir2016j copier needs solution
May 23, 2008 | Sharp AR-M350N Copier
143 people viewed this question
jasbo
jasbo
