Question about Siemens SpeedStream 4200 (13A4200001) Bridge
Siemens Speedstream 4200 NetComm V300 on VOIP
I have an ADSL service with Bigpond using a Siemens Speedstream 4200 and recently connected a "My Netfone" VOIP service using a NetComm V300. At least once a day the Netcomm V300 goes into "bootup" phase where the line and phone LEDS flash simultaneously and the VOIP servive is off the air. The NetComm V300 has be powered down for at least a minute for the VOIP service to be restored. I have tried to simulate the problem by disconnecting the interent, disconnecting the phone line, powering down either or both modems but cannot get the event to occur. I am wondering whether it is a setting in either modem that requires changing or an incompatability problem.
Can you help?
  • kho05032 Jul 02, 2008
    This is how the WAN is setup:-
    WAN STATUS
    WAN MODE :
    DHCP mode
    Current State :
    Active
    WAN IP Address :
    10.0.0.1
    Subnet Mask :
    255.255.255.0
    Default Gateway :
    10.0.0.138
    Primary DNS Server :
    10.0.0.138
    Secondry DNS Server :
  • kho05032 Jul 07, 2008
    I thought Latoof had the answer. The modem went for 2 days without failure but has reverted back to failing at least once a day. In your comment are you saying to set all IP addresses to 10.0.0.1?
    Sergeant:
  • 287 Answers
When the V300 Line/Phone led flash in alternating fashion, it's telling you it's WAN connection is dead. The WAN light is off too. so internet and VoiP phone will not work
When the V300 Line/Phone led flash in sync, it can't register to the SIP server.
The V300 does not appear to be listed on the Mynetfone website though. Have you checked to see that your V300 has the latest Firmware. LINK
It may be that the V300 is not getting it's IP renewed. Can you alter the IP lease time? Do you have the V300 set up for PPPoE, or do you have it set to static or DHCP (refer CH4, page 25)
Posted on Jul 01, 2008
  • Dave Jul 02, 2008
    Can you try setting the WAN mode to STATIC and using the IP of 10.0.0.1 and if required input the same values for any other fields too USERGUIDE refer page 27
  • Dave Jul 07, 2008
    From your post 2/7 , the WAN side of the V300 is set to DHCP clientso it gets it's IP from the speedstream 4200. I'm suggesting that you try seting it to STATIC and defining the IP as 10.0.0.1
    If this does not work then set the WAN back to DHCP and try setting the LAN DHCP SERVER to disabled. I am not 100% here but it seems to me that we have 2 DHCP servers one in the modem and one in the V300. I am not sure if they are "isolated" so it is worth a try.
    Post back results and we can go from there. I must admit I am learning a few things along the way here too LOL
    Another possible fix is to put the modem in "bridge" mode and set your V300 up for PPPoE.
How can I obtain a user guide for Acatel optus one touch 250 P/N16513 corded phone?
Optus Network Approved modem and equipment list
If you are supplying your own DSL modem and/or telephone filters, you must ensure they meet the requirements
below before connecting them to the OptusNet DSL network. Connection of unapproved equipment is prohibited.
The modem list contains equipment that has been certified by manufacturers as having passed interoperability tests
r
equired for use on a DSL network. If your modem make and model isn't listed below,
call Optus Customer Service for further information on
1300 309 333.
F
ully supported by OptusNet DSL Broadband Customer Service, the OptusNet DSL Broadband Installation CD-ROM will automatically
c
onfigure this modem.
D-Link ADSL Modem 302G
The OptusNet DSL Broadband Installation CD-ROM provides detailed information to manually configure these modems, and OptusNet
DSL Broadband Customer Service will provide limited connection support for them.
(Equipment Certification date in brackets)
F
or modems and routers other than those above, OptusNet DSL Broadband provides only the network connection settings needed for
manual configuration. While this equipment can be used on the OptusNet DSL Network, no OptusNet DSL Broadband Customer Service
will be provided for connection configuration or equipment-related connection difficulties.
Alcatel SpeedTouch - 510 ADSL Modem (15.01.2003)
Alcatel SpeedTouch - 530 ADSL Modem (15.01.2003)
Alcatel SpeedTouch Pro - 4 port (10.09.2001)
Alcatel SpeedTouch Pro - Firewall (09.10.2001)
Alcatel SpeedTouch PCNIC (04.08.2000)
Alcatel SpeedTouch USB (04.08.2000)
Askey/Dynalink - ALE 070 (08.01.2001)
Askey/Dynalink - ALH 110 (21.03.2001)
Askey - RTA100 ADSL Modem (25.10.2002)
Billion Electric - BIPAC-711 CE ADSL Modem (25.10.2002)
Cisco WIC - 1ADSL-DG (30.06.2003)
Cisco 827 (19.02.2001)
Cisco 827H (11.07.2002)
Cisco 827-4V (19.02.2001)
Cisco 837 (01.04.2003)
Cisco SOHO77 (29.11.2001)
Cisco SOHO77H (11.07.2002)
Cisco SOHO97 (01.04.2003)
D-Link ADSL Modem - DSL 100D (08.08.2001)
D-Link ADSL Modem - DSL 500 (08.08.2001)
D-Link ADSL Modem - DSL 504 (08.08.2001)
Efficient Networks - C10 Communications - Speedstream 3060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 4060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 5260 (08.01.2001)
Efficient Networks - Siemens - Speedstream 5400 (07.04.2003)
Efficient Networks - C10 Communications - Speedstream 5660 (21.03.2001)
Efficient Networks - C10 Communications - Speedstream 5667 (10.09.2001)
Efficient Networks - C10 Communications - Speedstream 5861 (21.03.2001)
Juni NetAce - ADSL USB Modem (15.01.2003)
Juni NetElite 2000ES - ADSL 4 port Modem (15.01.2003)
Juni/Samsung SAM-215 USB Modem (18.07.2001)
Juni/Samsung SAM-335A Ethernet Modem (18.07.2001)
NetComm ADSL Modem - BusinessSmart (08.08.2001)
NetComm ADSL Modem - USB - NB1200 (27.08.2002)
NetComm ADSL Router Modem - NB1300 (20.11.2002)
Open 501r ADSL Router Modem (05.04.2002)
Alcatel - Central, Part No. 3AU 04804 AAAA
Alcatel - In-Line, Part No. 3AU 04805 ABAA
Askey/Dynalink - In-Line, DT60-002BA
C10 Communications - Dynamic - In-Line, C10290
C10 Communications - In-Line, C10611 & C10611T
C10 Communications - In-Line, C10645 & C10645T
C10 Communications - In-Line, C10610
Te
l
ephone Equipment - Central, TE-ACP20AUS01
C10 Communications - In-Line, C10211
C10 Communications - In-Line, C10111
C10 Communications - In-Line, C10145
C10 Communications - In-Line, C10245
D-Link - Central, DSL-10SP
D-Link - Central, DSL-10CF
D-Link - In-Line, DSL-10MF
Alcatel SpeedTouch Home
D-Link ADSL Modem - DSL 200
D-Link ADSL Modem - DSL 300
D-Link ADSL Modem - DSL 300+
D-Link ADSL Modem - DSL 302G
Optus supplied modem
Optus preferred modems
List of all other certified modems/routers
List of certified filters/splitters
Information correct as at 2 February 2004.
1270049 06/04
Nov 12, 2014 | Cell Phones
No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username (john_citizen@optusnet.com.au) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
Jul 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Can't get connected
1.open your web browser and and type http://192.168.254.254 to access the DSL web page
2. click on the setup button to configure the dsl. the following are very neccessary to get the modem running
VC,DHCP,ISP password all in the setup environment
your VC must come from your isp so talk to them about it
am using the same thing in my office
Apr 22, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Sleeping modem?
hmmm..sleeping modem disease..rare but there is an antidote...you may find that this is something that's in your network connections settings, and there fore, your modem is fine..check for any time out settings, in your network connections settings area. might be on advanced tab.
check your computers warranty here 4 FREE
Mar 22, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Voip and speedstream 6520
hi, XBRMann
re 6520 seimens wireless modem
i have DSL internet connection
when the phone call dies i hang up the phone and call again for the same amount of time 3mins and 18 secs
i am using the seimens modem/router with the voip adapter connected via ethernet cable
i have updated the seimens modem/router with the latest firmware from the telstra site E752-AF5-106-71-a056-v1s
lkratzma
Jan 28, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Cant connect to "SOUL" adsl
First, just so you know, some devices (modems) just will not work on a provider's (ISP) network.. did you call your Internet Provider and ask it this device is compatible?
When you updated the firmware, did you receive any messages about failures? any messages at all?
Dec 22, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Speedstream 4200 setup
I have just set up 4200 with dsl - you may find that you need to reset modem before you can configure. I was told that you need either a grey or yellow cable from your laptop to the modem. I use 10.0.0.138 to access modem. The 4200 I have was from a bigpond a/c - originally configured accordingly.
Regards,
Richard
Nov 12, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens Speedstream 4200 Driver
Visit this link http://www.modemsupport.com.au/. On the left side under the heading Speedstream 4200 download and isntall both the drivers and firmware.
Once you've installed the firmware open iexplorer and goto http://192.168.254.254 . Type in an admin password and save settings. Type in your username and password ( provided by your isp ) press save again and then press connect. you should be in business.
Nov 09, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Cant connect my router
what is the source of your connection thru telepon line or a broadband connection or DSL?i need to know this........
Jul 16, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
462 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
