4400 software hi i am looking the software used to program telephone pin codes in a alcatel 4400 pabx please can you assist me as i cannot seem to find the necessary software elseware
  • kubang Jul 01, 2008
    need help asap
  • 36 Answers
Need instructions on how to use ALCATEL A382G
I NEED PUK CODE FOR ALCATEL A382G PLEASE
Dec 06, 2012 | Alcatel Cell Phones
My alcatel phone is locked up by the puk code how do i get it unlocked?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 18, 2011 | Alcatel Cell Phones
Need my puk code for my alcatel phone
OR:
Jul 23, 2011 | Alcatel Cell Phones
I have 3 lines from our provider, the lines already connected on the PABX. Only 1 line is program.. the other 2 line is not program on the telephone.. can u give me how to program the 2 line in the...
For a couple of reasons, No. However, if you access system programming, you can look at a couple of program locations to see whether the lines are turned on in software and how the system was restricted. Generally, program 400 assigns CO lines (in a TA cabinet) if the original installer used that method. The lines have to be enabled and appear on a phone to work. If you press lines 2 and 3 on the phone and the display says something, then it probably was the method used to turn them off. The other possibility was that they just restricted access by extension :-(.
It's a lot of work for nothing. That's changed in the 400's (407-409) IIRC.
Pick up a copy of your system's programming guide (PG) and it will tell you how to do it.
Carl
Jan 13, 2011 | Panasonic KX-T7730 Corded Phone
How do I update the time on the panasonic kx-t7730
that is not pssible to set from telephone
there is a PABX device (panasonic kx-tes824 ) fixed in wall
from that PABX check 101 extension number (maybe 10, wich phone connected jack1 )
from there is only you can program
Please let me know this useful
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
How do I change the time on my KX-T7730 telephone.
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset still on the cradle press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done.
Please rate this answer if it was helpful.
Thank you.
Jun 15, 2009 | Panasonic KX-T7730 Corded Phone
Call divert not working
normally this feature is enabled by the phone co. this allows you to activate and de activate the call divert
so call the phone co and ask them is this feature enabled on your line and what are the codes you use to turn feature on/off
i am referring of course to a single business line and not a pabx environment...i hope this helps in some small way
Dec 23, 2008 | Alcatel Lands Phones
ALCATEL 4028/4029 PHONE. WOULD LIKE TO KNOW IF IT PLAYS MUSIC SO I CAN HEAR IT WHILE I WORK?
Depends which Alcatel system the 4028/4029 is connected to.
If OXO, you will require an external music source to be connected to the AUDIO-IN port on the CPU (RJ45 plug using pins 1&2) and is recommended to install MOH/Paging isolating transformer. To enable background music on 4028/4029, hold the green speaker key for several seconds. Starts flashing and the volume can be adjusted with the + & - beside the mute key. To disable, just repeat hold process.
If OXE, will require engineer to program softkey & again will require an external music source...
Good luck...
Sep 03, 2008 | Alcatel Lands Phones
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
