Re: hp pmd 1600s ....no 'ok' button displayed on installer window
Problem solved...totally disregarded the install info and simply use the drive for storage.
Many thanks for your interest.
David
Posted on Jul 02, 2008
Pmd to pdf
PMD stands for Adobe PageMaker also called PageMaker Document. You can down load PageMaker free from Adobe. https://www.adobe.com/cfusion/tdrc/index.cfm?loc=en%5Fus&product=pagemaker Have a Nice day.
Feb 12, 2014 | HEWLETT-PACKARD HEWLETT PACKARD - HP -...
Need to align ink cartridges
Follow the steps to align newly installed cartridges.
  • When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  • Press the button next to OK on the control panel display.
  • The product prints an alignment page.
  • Place the alignment page print-side down on the right front corner of the glass.
When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer
  • Double-click the HP Digital Imaging Monitor icon ( ) on the lower right side of the Windows taskbar.
  • The HP Solution Center displays.
  • In the HP Solution Center, click Settings . Then click Printer Toolbox .
  • The printer Toolbox displays.
  • Click the Device Services tab.
  • Click Align the Print Cartridges .
****If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 05, 2013 | HP PSC 1210 All-In-One InkJet Printer
How do you disable the on board videocard on a hp p6130f?
Turn on the computer. Press the left "Ctrl" key. When the start-up menu appears, select "Safe Mode" and press "Enter." Once the computer enters safe mode, click the Windows "Start" button. Go to "Settings" and open "Control Panel."
Double-click the "System" icon. Choose the "Device Manager" tab. Press the "+" next to "Display Adapters" to view installed display adapters. Highlight the adapter listed and click "Remove" then "OK." Close all open windows and restart the computer.
Press the "F1" key at the blue HP screen. Enter set-up and press "F5" and "Enter" to reset all data. Press "F10" to save and exit.
Right-click the "My Computer" icon on the desktop. Select "Properties" from the menu. Click the "Hardware" tab, then the "Device Manager" button. Expand "Display Adapters" and right-click the graphics card. Select "Update Driver" from the menu.
Choose "No," and hit "Next," then select "Install From a List." Select the option to show all hardware. Choose "Standard Display Types." Select "Standard Display Adapter (VGA)" and hit "Next." Don't restart the computer.
Click the Windows "Start" button. Go to "Settings" and open "Control Panel." Click "Add/Remove Programs." Remove any i810 and i815 chipset programs. Restart the computer. After it starts up, go into the "Display Adapters" section in "Device Manager."
Open the "Standard Display Adapter (VGA)." In the properties window, un-check the box "Exists in All Hardware Profiles." Click "OK" and shut down the computer. Open the computer case. Install the new video card according to the manufacturer's directions
hope this helps
Aug 26, 2012 | HP Computers & Internet
I want online conversion PMD file to PDF file.
Here are directions: http://www.ehow.com/how_7375408_convert-pmd-files-pdfs.html
You can also try using ZamZar (http://zamzar.com/) or installing a free PDF printer like PDF Creator (http://sourceforge.net/projects/pdfcreator/).
Hope this helps!
May 31, 2011 | Computers & Internet
Deleted PMD file
If you have not disconnected the pocket drive, have a look in the Recycle Bin, if it is still in there click on the PMD folder to highlight the folder and click on File - then click Restore.
This will then restore the PMD folder to the pocket drive.
If you don't see the PMD folder in the Recycle bin, you may be able to download it from the HP WEB site.
Jun 23, 2009 | Computers & Internet
Can't find XP compatilble video driver
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP Windows version of the drivers you require and install them.
Use this link to download the drivers
http://h18000.www1.hp.com/cpq-country/cpq_support.html
May 22, 2009 | Compaq Computers & Internet
Ink system failure
Step1: Get into support menu by following the steps:
Press & hold the * Key then press # key.
Display says “enter special key combo”, Press OK on it.
Press & release 1, 2 & 3 keys in sequence.
Display says “Support” & FW rev. then go to Step 2
Step 2:
a. Press and release the right arrow button twice.
b. Display should say “System Configuration Menu”. Press and release the “OK” button.
c. Display should say “Hardware failure status”. If not there already, press the right Arrow Key over to “Hardware failure status”,
d. Press and release the “OK” button.
e. Display should say “Hardware failure status: Clear. Press OK to clear”. Press and release the “OK” Button.
f. Display should say “Hardware failure status Cleared. Press Cancel to continue”.
g. Press and release the “CANCEL” button as many times until the “Welcome to Photosmart Express” window appears.
h. Turn the unit off and then on by using the power button on the control panel, continue with the installation/setup of the unit.
1. If the error is still there, then perform the power cycle.
If it works it is good, if not if your printer is in warranty you will get the unit replaced for free from HP.
If not call HP and get a Out Of Warrnty Upgrade option where you will get a good discount,
Call 1800 474 6836
Good Luck
Aug 13, 2008 | HP Photosmart 3310 Printer
I am trying to backup my computer to PMD, But every time get an install error saying (the INF file you selected does not support this method of installation.) I did't have this promble when the PMD was in...
You may have a corrupted driver for your PMD. See if the manufacturer as a driver or HP.
Microsoft Windows drivers must have an INF file in order to be installed. An INF file is a text file that contains all the information necessary to install a device, such as driver names and locations, registry information, version information, that is used by the Setup components.
Jun 29, 2008 | HP Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
