How to remove the inside front door skins to replace speaker on a 2003 landcriuser
  • guffry Jul 01, 2008
    so fast, thank you so much
    Master:
  • 638 Answers
For the complete details n step by step instructions with diagrams to repair n replace any part of ur car.i m providing u the link below.:
best site for reparing cars
http://www.ptdoityourself.net/tl/tl_indexmain.html
and
http://en.allexperts.com
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jul 01, 2008
  • 796 Answers
On the covers there will be push inside out plastic rivets like screws...
press in the center of those screws and it will pop out a bit and then pull it out...then the fibre will be unscrewed ...pull it out and then you are done...
you will be able to access the speakers
  • isaac johny
    isaac johny Jul 01, 2008
    also check out for normal screws...they also will be present
Remove door lock hiace van
the factory Service manual covers this (buy one if DIY or get service)
you never said what door?
if front passenger/driver door, all cars are much the same.
1: remove door card (the inside skins) and handles first.
arm reset on some.
2: remove the card skins, some unscrew, some just pop off from bottom to top.
3: remove plastic sheet (thin) if still there (moisture barrier)
4: see lock , sure, remove link clips (they turn and unlock)
5: unbolt lock.
Dec 05, 2014 | Toyota HiAce Cars & Trucks
Tyre pressure chart landcriuser 100 series
There is a tire pressure chart on the driver's door (visible on the end while open) or on the door of the glove compartment.
May 04, 2014 | 2000 Toyota Landcruiser Duraflex Platinum...
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Door handles and locks
you will have to take it apart to know for sure.
But chances are good that you will only have to replace the handles.
the cylinders should be ok as long as the key goes in and it works.
Nov 10, 2009 | 2003 Chevrolet Silverado 1500
I wqant to remove door 'skin
No you cant do it, Unless you are experienced body man.with all the tools welder ect.
Sep 21, 2009 | Toyota Camry Cars & Trucks
I am looking for a diagram or picture as to how to get to the speakers to replace them on a 97 villager??
Section 15-03: Speakers 1997 Villager Workshop Manual DESCRIPTION AND OPERATION Radio Speakers All vehicle sound systems are equipped with radio speakers (18808) located at all four corners of the vehicle. The radio speakers are mounted in the RH front door (20124) and LH front door (20125), as well as behind the quarter trim panels (31012) in the rear of the vehicle. The Ford Super Sound Audio System has the addition of a subwoofer mounted in the RH quarter trim panel.
Radio Speakers, Front Door Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 .
Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  2. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
  3. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screw from the door pull handle.
  2. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  3. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
  4. Remove the front door trim panel.
Door Electrical Connections
Removal and Installation
Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
Removal
  1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
  1. Remove the front door watershield by carefully detaching it from the adhesive.
  1. Remove the four front door radio speaker screws.
May 20, 2009 | 1997 Mercury Villager
Door window repacement
moz-screenshot-2.jpgFirst you need to take off the door skin... depending on options like power windows and locks this procedure varies.then
  1. Disconnect the negative battery cable.
  2. Remove the door trim panel.
  3. Remove the silencer pad and water shield.
  4. Remove the side view mirror trim cover and door frame trim molding.
  5. Remove the front door speaker.
  6. Move the glass to the down position and remove the glass-to-lift plate fasteners.
  7. Loosen the door glass slam bumpers.
  8. Lift the glass upward through the opening at the top of the door.
Aug 24, 2008 | 1993 Dodge Shadow
Front Speaker Replacement
you have to take off the door panel usually there is screws inside or around the handle then sometimes some around the edge of the door where the door striker meets look for caps thaty pop out and make sure all screws are out then the rest pops off take a flat head screw driver or something similar and put it between the metal part of door and panel right there close to where the door latch is (where the striker plate meets) then get your fingers up under and do small jerks where the window is slide up and run door handle thru opening
Feb 06, 2008 | JC Whitney 4-1/2'' Front/Rear Replacement...
Glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Jan 27, 2008 | Ovens
Replacing front and rear speakers in a 1999 Mazda Protege
Whats the problem?
Back - Remove speaker grill, unscrew, climb in trunk, unplug - remove.
Front - Remove speaker grill, unscrew, pull out, unplug. If you have problems remove window winders and door skins
Dec 15, 2007 | Car Audio & Video
 Grubhead
Grubhead
