Question about Cameras
I have a Samsung D760 and bought a 1GB SD memory card for it but cannot find a slot to insert it. Will this camera only support external memory?
Hi . Please tell me if the samsung d760 is good because i want to buy and i am not sure if it a good product .... please answer quicly
Posted on Aug 20, 2008
The slot for memory card is just on the top of place where you insert the 2XAA battery.
Posted on Jul 15, 2008
Its in the place where the bartery goes
Posted on Jul 10, 2008
Memory card error
Make sure your camera can take San Disk. It probably takes a certian card or the SD card might be upside down. Some brand and models stay this fault and the problem with the SD is that it does not accept a memory card higher than 1GB. This info isn't in the user guide. Have you tried an external usb card reader?
Pull the card out and re-insert. the most likely problem is the card was not seated properly in the slot.
Keep us updated.
May 28, 2011 | Canon PowerShot SD950 IS Digital Camera
Says Card Error
Keep us updated.
May 17, 2011 | Vivitar ViviCam 5386 Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
Where can I insert my mini sandisk memorycard into my toshiba laptop? I see no slots for it.
If you have no SD slot on your laptop, you will have to buy an external USB SD reader. They typically cost $5-$10, and are readily available online (e.g. http://www.buy.com/prod/micro-sd-sdhc-card-usb-reader-for-1gb-2gb-4gb-8gb/q/sellerid/23962916/loc/101/213271933.html) or in almost any store with a good selection of electronics.
Dec 06, 2010 | SanDisk 2GB microSD Memory Card
I bought a 4GB Memory Card for my Samsung Digimax D53. I put it the camera and Try to format it but it says check sd card. I tried another 1GB memory card and it worked. I know that the problem is with my...
Unfortunately, you can't. The D53 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. Since this is a hardware issue, it is not something that can be changed with a firmware update. You need to use cards 2GB and smaller.
May 14, 2010 | Samsung Digimax D53 Digital Camera
How Do I/Where do I put this thing in my phone
Stick the microchip into the adapter(s) and insert it into a sd slot on your computer if you have one. If you dont have an sd slot, they sell external systems for sd cards at any electronic store that carries computers such as best-buy. This should FixYa!
Jan 27, 2009 | SanDisk 1GB microSD Memory Card
Memory card Samsung Nv3
This is a common problem and I had the same issue. Samsung only guarantees that a 1GB external memory card will work. If you look at the user manual on page 77. I just used a 1GB memory card instead and it worked fine.
I am not saying that no memory cards greater than 1GB will work but I would try to find someone that has used the brand and size and knows that it will work.
Sep 08, 2008 | Samsung NV3 Digital Camera
Memory card problem
Are you sure you have the right type of memory card? Make sure you use an SD/MMC card. You might try another SD card.
Is this a new camera? I bought one once and the card slot was defective. I took it back right away, rather than trying to force a card into it.
Mike
Nov 21, 2007 | Samsung Digimax A400 Digital Camera
My New Micro SD Memory Chip
i need help. i insert my lexar 1gb micro sd memory card into my phone and my phone doesnt show that there is a memory card inserted and i have no idea how to work it on my phone. my phone is a samsung blast.
Jul 31, 2007 | Samsung SGH-D900 Cellular Phone
Cameras Logo
213 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
