Question about Samsung SGH-D900 Cellular Phone
Voicemail I accidentally turned off my voicemail and now cannot turn it back on. I think I went into Settings, probably Network Settings but cannot remember what I did. ?deactivated Call Diverting or did something to Voice Server. Can anyone help bc I cannot remember what I did and now callers can only send a text msge w my number, not leave voicemail messages. Eve
Go to settings and reset ur phone is doing a same thing then u must enter this # (*2767*3855#)
Posted on Jul 03, 2008
My phone keeps fading off and won't switch on, cuts off in mid-text, doesn't ring, goes straight to voice mail and the phone is only a year old. Screen constantly goes blank. Help!
Missing calls on your iPhone? Or finding that your iPhone calls go directly to voicemail, and don't know why? You're not alone.
In this article we discuss some simple issues that may be causing calls to be diverted, and explain how to fix them. Read next: How to manage voicemail on iPhone
Check for iOS updates This is a double-edged sword. It's possible that a recent update to iOS has caused the problem (but if so, it should be patched soon); it's also possible that an update will fix it.
When Apple updates iOS it's inevitable that some things will go wrong. Most of these should be picked up in the beta. but a few will slip through to be patched at a later date.
When iOS 7 came out back in 2013, for example, some iPhones suddenly found that incoming calls were being directly transferred to voicemail. The option has since been disabled by default.
If you've noticed the voicemail problem since updating iOS, there's a good chance that the two things are related. Check for any new updates since then, which are likely to include a patch. Read more:
Do Not Disturb mode If the problem persists, Do Not Disturb mode may be the issue. Perhaps you turned it on by mistake, or turned it on and then forgotten about it. It may even have been switched on against your wishes by a glitch in iOS.
You can tell quite easily if you've got Do Not Disturb switched on, because there will be a crescent moon icon in the top right of the iPhone's status bar, next to the Bluetooth and battery icons.
When Do Not Disturb is enabled, calls and alerts that arrive are silenced: that's the reason your calls are being diverted before you have a chance to answer them.
The quickest way to turn off Do Not Disturb is via the Control Centre. Swipe up from the bottom of the screen to bring this up.
The Do Not Disturb icon is in the top row: it's the crescent moon. Tap this and it will turn from purple (switched on) to grey (switched off).
In iOS 11, which at time of writing is available in beta and comes out officially in autumn 2017, Control Centre looks a bit different, and the precise controls shown are customisable - but you'll always see the Do Not Disturb toggle. It's the same as before: a crescent moon.
Alternatively (although more slowly), you can turn it off via the Settings app. Open the Settings app and in the second batch of options underneath Notifications and Control Centre, you'll see a purple icon with that crescent moon and the words Do Not Disturb.
Click on that. Move the slider on Manual so that it's off - so there's no green on the slider.
How do I stop my iPhone going to voicemail after just three rings? This is a slightly different problem. Your voicemail isn't controlled by the iPhone itself, but by your network provider, and you have to adjust these settings by dialling your network and using a phone option.
First of all, check there isn't something weird going on with your network settings. Go to Settings > General > Reset Network Settings, then enter your passcode. This will ensure that you have the right settings for your network.
Whether you can change the length of time that the phone rings before going to voicemail depends on the network provider. Some, like Vodafone, enable you to change this using their automated system. Others require you to call up, or the amount is fixed.
Vodafone
Vodafone enables you to choose the length of time a phone rings before going to voicemail. According to the Vodafone instructions:
  • Enter **61*121*11*[Number of seconds]#
Then enter the number of seconds you'd like your phone to ring for (it has to be between 5 and 30 and a multiple of 5), followed by #.
For example, if you want to set if for 25 seconds, you'd enter **61*121*11*25#, then press call.
Vodafone will send you a text letting you know if this has worked.
Three
To adjust voicemail settings (including turning voicemail on or off) you need to call three on 333.
To turn off VoiceMail on the Three network, dial "333" and tap the "Keypad" in the Phone app. Press the the following buttons
  • 2
  • 1
  • 2
  • 3
  • 1
  • 1
You should get a text from Three stating that you have successfully turned off voicemail. To turn it on again go through the steps but change the last entry to "2
O2
O2 has a direct line to turning voicemail on and off. Just dial the following numbers direct from your phone.
  • Turn voicemail off: 1210
  • Turn voicemail on: 1750
Aug 25, 2017 | Cell Phones
I am unable to access voice mail. Dont know pasword. Never used before
Hi Jerry
  1. Call your iPhone from another phone and try to leave yourself a voicemail.
  2. Reset your network settings by tapping Settings > General > Reset > Reset Network Settings.
  3. Reset your voicemail password.
  4. Contact your carrier and make sure that you have the voicemail feature on your plan.
Mar 05, 2016 | Cell Phones
Voicemail problems
Excuse this very basic answer first, but it's the simplest fix. Have you checked your Cellular Data feature is still turned on? Go to the Settings app. Select Cellular. Slide the circle to the right.
If it's not this simple fix, some people have had luck with the Reset Network Settings option. Go to your Settings app. Select General > Reset > Reset Network Settings. Lots of people have perfect luck with this, but others have found that the problem recurs.
Another option is to call your carrier. You do not mention who your carrier is, but Voicemail issues are often a carrier issue and not a phone issue. Some people have had luck by calling their carrier, or going on their carrier's website and resetting their voicemail passwords.
Good luck to you!
Aug 08, 2014 | Apple iPhone 4 Black Smartphone
How do i turn my voice mail off on orange network?
Usually when you call your voicemail number there is a voice menu that gives access to settings, where you can configure the voicemail and turn it off as well.
If you have trouble with the above, you can also leave the voicemail available, but prevent the network from redirecting calls to it when no answer/not available.
For that you'll have to browse your phone's menu and find "Call Diversion" in your phone's connection settings, and turn off all 3 diversions: on no reply, on not available and on busy.
Hope to have helped.
Jul 22, 2011 | Cell Phones
I have accidentally pressed 15712, which turns on automatic voicemail. How do i reverse
To remove the voicemail diversion and return to your standard voicemail settings after the conference call, dial 15713 and press SEND.
Mar 28, 2011 | Cell Phones
How do I turn my voicemail Back on on my NEC Dterm series E?
call your service provider and they will turn it on for you...if its still not working go onto settings, network settings and then voice mail...hope it helps
Sep 04, 2009 | Lands Phones
How do you get the phone to ring for a longer time
On the phone settings, >> tone>> select the RINGING type, in able to get a continuous ring if someone has call your phone.
Let me know for further instructions.
Aug 22, 2009 | Sony Ericsson C510 - Pay Monthly Cell...
Voicemail icon is blinking and I have no messages
Aftre checking twice to ensure I truly had no remaining phone/text/etc. messages (i.e. not initially trusting the "you have no voicemail" lady), I still had the blinking Voicemail Icon on my Verizon (Casio) GzOne Boulder. I turned it off and on, and it simply went away. Reboots triumph again. Since most of us leave our phones on 24/7, betting many don't try a repower/reboot. This is also way less risky than having some new Tech Support person mess with your account ("remove voicemail and put it back on", per the above comment). Until they have less buggy software/firmware, simply reboot.
Aug 15, 2009 | Casio G'zOne Boulder Cell Phone
PS3 Input Problem Please Help
Turn off your PS3 and then hold the power button down for 10 seconds. You should hear two beeps and the PS3's resolution should be set back to the default.
Jul 13, 2009 | Sony PlayStation® 3 (80GB) Console
Voice Mail Message Indicator
i cant figured out the battery issue myself but you can reset the voice icon to zero through setting ...more...morephone settings then more again then hit the clear voicemail icon
Jun 09, 2008 | Motorola Mobility Moto Q
Samsung SGH-D900 Cellular Phone Logo
318 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
