Was given a LOGIK lcd tv but have no instructions on seting it up, our old tv has two scart leads and is connected to a Sky digital box, the new tv only has one scart outlet, what do I have to do I connected the tv up but only have a blue screen even though sky box is on. Help please, Paula
I was talking with a neighbour and he came and sorted it out.
Posted on Jul 02, 2008
Connect hdmi goodmans tv
Forgive on this one but I do not have a soundbar but wonder if it has any other connections like phono for input as to me hdmi would be a strange choice. Hdmi leads are mostly alike in they are fully wired and carry a wire which directs a device to listen to it when turned on, also some hdmi sockets (like the old scart) are blessed with options.
Some may be input only while others set for in and out so it may be worth swapping connections on your TV to see if this changes the habit, though for me I would look to see if this soundbar has other sockets to use like phono (same with your TV if it has phono or scart socket options). Your TV instructions may show their ideal connection setup, otherwise you will have to shutdown your other item to stop it commanding the TV to switch through its sound. This "problem" is an old one with people using scart leads then I used to cut pin 8 (its control wire handing the descision to a user) but this new lead combo I do not know.
Hope this helps.........
Aug 29, 2017 | Samsung LN32A330 32 in. LCD TV
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
Just bought a Logik tv with integrated Freeview. I have sky+ and the TV plays from the Sky receiver but blocks all non freeview channels, for which I subscribe, how do I get the TV to play ALL the sky...
It sounds like you've just got the TV on the Freeview.
I presume your Sky+ is connected via a Scart Lead to an AUX Scart Input on the rear of the TV.
You need to change the TV from Freeview to the AUX Input, should be a button marked AUX.
If you can't figure out how to do it then please advise the Model of the TV and I'll try and talk you through it.
Jun 15, 2011 | Televison & Video
How can I tune in sky to a logik tv with built in freeview ?
You just have to treat it as you would like adding to it so you would need a dish for the lead of the sky box to be plugged in to and a scart lead to go straight to your telly to the sky box I hope this has been of some help has you would need a sky box to gt the sky channels I wish you good luck Karl
Jun 05, 2011 | Televison & Video
When i plug my new tv into the sky box via a scart, the tv picture is distorted and a major buzzing noise is coming from the tv. sky have checked and said the box is fine. when u connect to another tv it...
Have you tried another scart lead? Also tried all of the tv scart sockets? Don't try and cure this by using an expensive upmarket scart lead, you'll just be wasting your money. The cheapest leads work just as well when the function correctly.
You could also try reversing your current lead by swapping the tv end to the Sky box and vice-versa, as there are many leads which cause feedback issues, and also a lot of "cut" leads (designed to prevent feedback looping) which must be fitted the correct way around. A "cut" lead is one where the wire to pin 19 at the tv end and to pin 20 at the video/Sky box end has been cut.
Note that scart leads MUST be fitted with the tv and Sky box switched off to avoid damage. Most people (including professional installers) regularly ignore this precaution though.
If all else fails then take the tv back and exchange it under the Sale of Goods Act; it's certainly not uncommon for new tv's to have faulty scart sockets.
If I've solved your problem then please take a moment to rate my answer. If not, then please report back with the make and model of TV and I'll try a more specific answer.
Jan 14, 2010 | Televison & Video
Hi, i have just bought a logik wireless av sender so send my sky signal to the tv in the bedroom. the instructions in the manual are very basic and i cant get it to work. any ideas. on the tv in the...
Red and white are only Audio ports.
IF there is a scart port plug your av receiver into the scart. Take note on which number your on ie channel there should be several numbers you can choose on your tx/rx then go down stairs to your sky box and ensuring that you are on the same number as the one upstairs.
Then just plug it into the back of your sky Box.. the number on your sender are incase your getting interfearance from other sources in the home. have a play with this and see what works best
Hope this Helps
Little Dish Fitter
Aug 22, 2009 | Televison & Video
Connecting sky box to to non scart reysis tv,via scart plug cable
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Jul 18, 2009 | Relisys RLT-1500 15" LCD Monitor
Sky
You do not say which breed of sky you have.. old analogue, digital, sky + or sky HD if you have old analogue then you may have to connect through aerial connection, digital will have a scart socket to connect to your tv, sky + will have the same and finally the cream of the crop sky HD will have hdmi in addition to scarts.
The very least you need to do for a digital picture (not to be confused with hi-def which it isn't) is connect through scart lead then unless it auto-switches to scart input upon switching on sky use your tv remote to select the ext input 1, 2 or 3 etc (some remotes have a button called source for this some call it input etc) select each ext input until you find the one your sky is connected to
Oct 12, 2008 | Televison & Video
Probem getting sky to work with a new TV
An HD TV connects in the same way as a standard TV.
Connect a scart lead from the TV scart of the Sky box to the TV.
When you switch on the Sky box it should automatically switch the TV to the correct external input.
May 19, 2008 | Televison & Video
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
