Question about TallyGenicom 6312 Matrix Printer
Error on tally genicom 6312
When ever i sent to printer th printer always stop and complain of paper motion fault please do advice me on time on what to do
thanks
ABUBAKAR
    Scholar:
  • 63 Answers
Found this on Tally Genicom's Website about your device.
Technical Services Note
MT6xx/T6xxx (All) Paper Motion Faults 11 May 1995
T645.039
If you are having problems with recurring Paper Motion Faults that don’t seem to stay
fixed by doing the paper motion sensor calibration, try the following:
· Check the back of the form along the left side to ensure there are no black (dark) areas
in the area of the tractor drive holes. (If there are, this is probably the problem. If not,
proceed on down this list.)
Clean the sensor on the upper left tractor then run the calibration routine again. If it’s
not better yet, continue.
With Tech Access ON, do the following:
Go into DIAG - Meters - Paper Motion and monitor the sensor reading with paper
installed and removed. If the reading with paper installed is in the 300 to 350 mVolt
range, change the sensor (even if it seems to run the calibration alright). A more
normal reading would be something greater than 600 mVolts for the MT691/6092 and
1000mVolts or greater in the 645/661. Don’t forget to recalibrate the sensor. If it’s
not fixed yet, try this next step.
Run a configuration printout and then do the following:
1. Clear the NV Ram (Tech Access feature ON)
2. Calibrate the Paper Motion and Paper Out sensors
3. Restore the configuration based on the print-out you just ran
http://www.tallygenicom.com/support/technotes/tnote/d5639.pdf
my site: www.techvisitor.com
Posted on Oct 31, 2008
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 80 Answers
JUST CLEAN PAPER MOTION SENSOR OTHERWISE LOGIC CARD HAVE TO REPLACE
Posted on Jan 06, 2015
WHERE DO I GET RIBBONS FOR THIS UNIT
Contact Printronix in Irvine, Ca. Printronix took over Talley/Genicom and they support these printers.
Mar 13, 2014 | Genicom Tally 6312 632 Adp Lp1500 Network...
Telegenicom 6312 printer has a paper out problem
there is a sensor that check the paper its mey be broken or jamed
Nov 10, 2011 | Tally 6312 Matrix Printer
I have a tally genicom 6312 printer which gives me hammer voltage 2 error what do i do
A high resistance coil fault has likely occurred in one or more of the hammer coils.
Note: this fault message will have been preceded by printing slow-down attempts associated with On-
The-Fly thermal monitoring of hammer bank temperature.
Check the hammer bank for defective coils.
If no defective coils are found replace the Controller Board.
Dec 31, 2010 | Tally T6218 Matrix Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Platen motion fault in tally genicom 6312
problem with platen sensor , clean the sensor with ipa still same problem change the platen sensor
Dec 06, 2009 | Tally 6312 Matrix Printer
Tally T6100
You lost the sensor calibrations. Grab the service manual. Do the four fault clear, enable tech access mode and calibrate paper motion, paper out and platen.
May 23, 2008 | Tally Line Matrix T6050 Printer
Paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Mar 12, 2008 | TallyGenicom 2280 Matrix Printer
Telly genicom printers
What do you mean picking papers. Do you mean feeding the paper, or printing with certain types of paper?
Aug 09, 2007 | Tally Matrix T2280 Printer
Paper motion fault
This info is from the Maint. Manual for T6212/T6215/T6218.
gp+3ytmzowxemaaaaaelftksuqmcc
xotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
0tzegsr+ic4n46ssuqv4el30qgpfj8tqefx2f8bvlqvvrw0muuaaaaasuvork5cyii=imeb+a4pe3uaaaaasuvork5cyii=
ak0nfwmwb8waaaaasuvork5cyii=
Jan 24, 2007 | Tally T6218 Matrix Printer
TallyGenicom 6312 Matrix Printer Logo
1,183 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
