Acer TravelMate 4500 USB ports doesn't work
My USB ports doesn't work at all after I have formatted and reinstalled the OS.
Can you Please assist.
Probably mainboard is broken, it's typical acer malfunction, power on usb port is still on (you can charge your mp3 for example) bout windows doesn't detect anything.
Posted on Nov 10, 2009
    Problem Solver:
  • 19 Answers
In a situation like this u have to check meybe the usb option is been enabled in the bios enviroment,if it is enabled and the usb port doesnt work then u have to un-screw the laptop and check meybe the usb wire conector is properly fixed on the board,if it is not properly fixed then u need to connect it properly,after that u will need to reformat your system using a different file system either NTFS or FAT32.
Posted on Jul 03, 2008
Good day. I have MSI U90X model MS-N11. I need to format and reinstall a new new but I lost the CD ROM board installer. Can you please help?
That doesn't quite make sense but it sounds like you want to reinstall with the factory OS image, or get drivers for your mini-notebook. Surely you should burn a USB key or DVD+R with a new free OS or mini distro (any one will have enough drivers.) Several distributions focus on models like that in particular.
Jul 25, 2011 | Computers & Internet
I recently intalled new Zune software for Vista, but my Zune player does not synchronize with my system.
If it doesn't connect, I suggest uninstalling and reinstalling the Zune software.
Try to use a different USB port you haven't used before, so Vista will reinstall the USB drivers for the specific port.
If that doesn't work, with the Zune in, go to Device Manager and uninstall and reinstall the drivers that are installed for in the DM.
Jun 11, 2011 | Computers & Internet
Cant open as a storage device on the pc
1 First connect it with ur PC with the data cable provided along with it.
Go to the My computer icon. right click on it. Select manage. one window will pop up select device manger and the in the right side a window will come . select the option of USB. The port with which ur hardware is connected will show with yellow error mesage. slect that port and unistall the driver and select the main menu of the USB and select the option scan for the hardware changes.
2 If it detects ur hardware device then ur device is ok no physical damage.
3 Reinstall the OS with the help of the CD provided along with this player
4 Read the manual carefully before installing the OS.
Please note that never format the MP3 player while installing the Os the manual caonatins step by step procedure to install the OS follow that only.
If you format the MP3 player then ur Mp3 player willl be permannetly damaged.
Jan 26, 2011 | Sony Walkman NWZ-B142 MP3 Player
Dell 1525 inspron usb not working
It is possible that the USB drivers are not updated .have the USB drivers reinstalled to check, if not have the system reset to an earlier restore point.
If this wont help the OS must be reinstalled as the software is corrupt hoping that there is no USB port problems in the motherboard due to poor connectivity...please have the other port also checked just in case it is port connection fault.
Sep 30, 2010 | Dell Inspiron 1525 Notebook
I reinstalled my OS win XP . now no usb
Open Run and launch regedit
Browse to the following location
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\USBSTOR
In the right pane, look for an entry named Start. If you find one delete it. Your USB devices should start working immediately.
If not please report back.
Nov 11, 2009 | Acer TravelMate 240 Notebook
Please I am in need of usb driver of motherboard asus 845 with dd ram1
The USB ports should be setup by the OS. Do the following:
Here is what you can do to refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 13, 2009 | Computers & Internet
Computer can't communicate with printer
whatever be the OS, get into control panel, go to printers and see the printer that you are using is set as default,,, there would be a check mark on that printer icon,, if not make it default,, and try again, If you are using a usb cable connect the usb cable of the printer to the back usb ports and try,, use the printer driver disk that came with your computer, perform a reinstallation of the driver
Feb 05, 2009 | Lexmark X2470 All-In-One InkJet Printer
Onboard USB prrs malfuntion
Try re-installing the motherboard drivers. Here's a link:
http://drivers.softpedia.com/get/BIOS/Asus/Asus-M2V-MX-SE-Bios-0502.shtml
Hope this helps
Chris (ziraffa)
Dec 20, 2008 | ASUS M2N-MX Motherboard
Laptop D600 Latitude's USB is not working
hi!
Have you tried reinstalling the OS? If reinstalling the OS still won't work, then the motherboard could be shot and needs replacement.
Hope this helps.
Karlox™
May 14, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
545 people viewed this question
David Payne
David Payne
