Question about Dishwashers
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
  • 3 more comments
  • Anonymous Jul 13, 2008
    pump continoues to run no water enering dishwasher
    thanks craig
  • Anonymous Jul 24, 2008
    Same as above, Eco light flashing, pumup running, no water in machine. Opening door does not stop anything
  • paulgen Jan 29, 2009
    I have a dishlex Global 300.We went away for the weekend and when I returned the dishwasher was draining and the eco light was flashing.We left the door opened when we left, so it started by itself with the door opened.
    We could not get it to stop.My husband had to disconnect the power to get it to stop.
  • Bloooo Apr 20, 2009
    Same - Eco light flashing, washer empty and pump continuously running. Had to diconnect from power to turn off.
  • rocketjo May 16, 2009
    global series dishwasher; i just replaced handle/lock on door; now no water is entering machine; making the right noises and all lights seem ok . any ideas ?
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Posted on Nov 05, 2008
  • Jaycedufty
    Jaycedufty Oct 26, 2013
    Tilt the hole unit on an angle so the emergency tray drains and wollar!
Dishlex Global 300 Dishwasher - ECO Light flashing - Manual indicates incorrect fill level - Manual suggests hold ECO button for 10 Seconds. No success. Have tried pressing and holding buttons - no...
eco light sometimes indicates that water has got into the bottom panel of the machine. A float switch is underneath to protect the machine ( and your kitchen floor from being flooded. ( Either from overfilling or a leak) If you tilt the machine backwards see if any water runs out. If the machine restarts , then you will have sourced the problem. Should the flashing start again later, you may have a water leak underneath. Also check the lower door gasket to make sure its clean. If the gasket is dirty, sometimes water builds up behind the gasket and drips over the front of the tub into the bottom panel underneath causing this symptom. When cleaning the gasket, be very carefull!! The edges of the door at the bottom are razor sharp..
Jul 26, 2011 | Dishwashers
The eco light is flashing constantly on my Dishlex Global 300 dishwasher, it is making a noise like a pump is running continously, but the unit will not operate. Can you give me some possible faults and...
The symptoms on a Dishlex Global 300 dishwasher:
  • eco light is flashing constantly;
  • noise on pump running continuously;
  • but the unit will not operate.
Possible corrective actions include:
  • water level - pls check incoming water pressure, filter, water level sensor, water valve;
  • base/bottom overflow sensor - there is a float switch in the base of the machine inside a small plastic dish. Behind the kick panel, access through a metal lid/panel/cover secured by 2 small screws. Dry completely the area;
  • Air/dry/ventilate the unit/system for a couple of days;
  • reduce incoming water pressure.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 26, 2008 | Dishwashers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Our Dishlex Global 300 appears to be stuck in Pre-wash. The Eco light is flashing and the water has drained. All other buttons are unresponsive. I have just replaced the seals and handle assembly.
If your getting 120 volts to your dishwasher, I would first ohm out your thermal fuse for continuity, turn your breaker OFF to your dishwasher first.
Jul 24, 2008 | Dishwashers
Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex global 300 dishwasher, eco light flashing sounds like pump noise but not working
Try taking the dishwasher out of its wall space and tipping it back and forth. Apparently the weight of water gathering in some component triggers the 'eco' function. Failing that, last time it happened to my dishwasher i waited a week for the repair guy to arrive, by which time the water had evaporated and there was no longer a problem..
Jul 26, 2008 | Dishwashers
Hi. I have a Dishlex global 300 series and it starts going through the cycle ok but after about 5 minutes it starts to fill up again and the eco light starts to flash and it won't stop filling up and...
The operating manual says under problem solver thatin such a situation it has an incorrect fill level or fill time and recommends then the need for a service agent.
Try holding the start and programme buttons down at the same time until the machine beeps. This will reset it in case it is just a computer problem.
Apr 30, 2008 | Dishwashers
Dishwashers Logo
1,411 people viewed this question
Top Dishwashers Experts
