Question about Hotpoint Aquarius WMA42 Front Load Washer
I have a hotpoint aquarious, and it will not pump ot the water. I have set the dil to pump out, but have to keep on turning it off and on, and it only pumps out about a tablespoon of liquid at a time. I am trying to locate the filter, so see if that is bloced but i dont know where it is.
The possible problems here are blockages or pump failure. Blockages are the more likely explanation but pumps can fail. If the washing machine will not empty the water out you may also not be able to open the door on some washing machines although these days it's much rarer to have a pneumatic lock on the door due to cost cutting (if a washing machine has a pneumatic door safety lock a rubber hose is connected to the door interlock from the pressure chamber bottle on the tub - water in the tub forces air up this tube and locks the door, which is released when the water is pumped out and the air pressure drops).
Some washing machines have a filter at the front of the machine that can be checked for blockages. Sometimes the filter is hidden behind a removable trim or panel at the base of the front. (Some Hoover & Hotpoint washing machines do not have any customer accessible pump filters - if in doubt it will tell you in the instruction book).
If your washing machine has a water pump filter and a filter drain hose you should be able to drain the water from the washing machine into a bowl without moving the washing machine. Open the pump filter flap and pull the small drain hose forward. Take the bung out and drain into a bowl. It's likely to be painstakingly slow but at least you don't have to try and pull out a heavy washing machine full of washing and water.
If your washing machine doesn't have a pump filter, or it has a pump filter but no draining hose then it's a bit trickier. To drain the washing machine, you will need to remove the drain hose from the drain pipe at the back of the washing machine, and lower it into a bowl or bucket. Many plumbers now plumb the drain hose into the U bend directly under the sink instead of a separate waste pipe at the back of the washer. If yours is connected directly to the u-bend, you can usually unscrew it easily. Remember though, that with the pipe disconnected from the U bend, any water poured down the sink will flood out into the cupboard until the hose is reconnected.
Once you have drained the water, you need to check for blockages in the pump by unscrewing the pump filter. If none is found, sometimes a blockage can occur in the plastic connector that the drain hose is connected to at the sink end (if connected this way)
Once you have the drain hose disconnected and lowered into a bowl or bucket the water should siphon out as long as the pipe is low enough. You are likely to get several bowls full of water from the washing machine. If little or no water comes out then it may be blocked by an item of clothing like a sock and it won't be possible to empty the machine this way or it is going to be a long process.
Once the last bit of water has drained out, the washing machine may now spin as the safety system for preventing a spin while water is in the machine will now recognize the water has gone and allow a spin. Keep the pipe low down and in the bowl or bucket and put the washing machine on a spin only program. Note, this last step is not strictly necessary as once drained, the door should open. However, you might prefer to try to spin a few more bowls of water out.
Clearly if you put more water into the machine it is likely to fail again until the fault is rectified but these instructions should at least get the clothes out.
Other possible obstructions could be inside the sump hose leading to the water pump. Many Hotpoint washing machines have a filter inside the sump hose which gets blocked. Finally, the pump itself can be faulty.
Posted on Jul 04, 2008
The solution came from this page, which has more pump advice
http://www.washerhelp.co.uk/washing-machine-parts/pumps.html#cl_q6
Posted on Oct 31, 2008
Whirlpool washing machine throwing water outside instead of taking inside. Please suggest me what I have to do for this problem
Karunakaru R
karunkarur@yahoo.com
Posted on Sep 09, 2008
Sep 10, 2017 | Hotpoint Washing Machines
Jan 13, 2014 | Washing Machines
Apr 14, 2013 | Hotpoint WMA40 Front Load Washer
Feb 27, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Jun 23, 2010 | Hotpoint Aquarius WD640 Front Load...
Oct 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Jun 13, 2009 | Washing Machines
Jan 12, 2009 | Hotpoint First Edition FEW12 Front Load...
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Apr 17, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Mar 28, 2016 | Hotpoint Aquarius WMA42 Front Load Washer
1,085 people viewed this question
hhn.n.bb
washer will not drain, cleaned filter, cleaned waste pipe please advise
