My computer won't start up
I had a lot of problems with it so i did a system recovery and now it freezes on the windows loading page what do i do
Hi Theresa,
Have you tried booting into safe mode? Press the F8 key during boot.
How about the selection Last Known Good Configuration?
Let me know if that works.
Posted on Jul 07, 2008
System freeze
I would try booting to safe mode then do a system restore
Jan 12, 2014 | RaidMax Sagitta
Emachines E528 laptop won't start
Try to boot it from safety mode.
and try to restore your system first.
If the restoring is failed, boot safety mode again and back up your files.
If you can't boot your laptop from safety mode, use anti virus program CD like norton.
Mostly, your system is messed up by adwares, spywares, and virus.
If all things fail, you should check your HD.
Jun 18, 2013 | eMachines E525 D260 Motherboard...
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
My gateway laptop won't reboot after system recovery
I would put in a Windows disc and see if that prompts windows to start and/or reinstall. Actually, can you send me the recovery disc via download? I am trying to fix my old laptop and cannot find the discs. lilly.murphy@yahoo.com Thanks much!
Nov 30, 2012 | Gateway NV55S04u PC Notebook
Won't turn on
You may have hard drive issues or corrupted window files, remove hardware and reseat it back in position, sometimes this will correct the problem, next sub out the memory one at a time, causes a lot of strange symptoms. If none of these works, use the recovery disc "if you made one" The final option is a computer store to resolve the issues.
Mar 05, 2012 | Dell Inspiron 1545 Notebook
My laptop turns on then freezes how do i fix this?
The music you have on your computer should have no bearing on your start up problem, this is more likely to be caused by a different area of the system such as a recently installed device or program.
Have your tried starting your computer in Safe Mode - press the F8 function key during the initial boot display and before Windows starts to load.
Further recovery actions will depend on which version of Windows you have installed (XP, Vista or 7).
If you can get into System Restore then you should try restoring the system settings back to a time before this problem started if possible.
If you can't use System Restore but can start in Safe Mode, then download a copy of CCleaner and use this to perform some house-keeping clean-up to get rid of temporary files, clean up registry entries etc as this may help.
If you can't start in Safe Mode then you will need to have access to your Windows installation media (CD or DVD depending on which version of Windows). For Vista and 7 you can try performing a Startup Repair - for XP you may have to do a Repair Install.
Dec 29, 2011 | Dell Computers & Internet
Not able to boot press F12 lauch startup repair (30 second) I have to wait keyboard not responding then windows is loading files and start bipping error
first, recover your files. You will need to use something like this data recovery program.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 05, 2011 | Toshiba Computers & Internet
I have 1 friends page that always causes my computer to freeze before it fully loads? I have windows XP, I have rebooted, doesn't help. All my other friends pages on FB work fine?
Try downloading the latest updates to Macromedia Flash player, and Java. Does your friend hava a lot of moving graphics on the page?
Bob
Aug 15, 2010 | Microsoft Windows XP Home Edition
I am unable to start up my emachine em250 netbook.
The most common problem occurs when there is an incompatible device installed or a device that interferes the boot up of Windows.
If you have recently installed a new device in your computer please remove it and also remember to remove all of the USBs attached to the computer. Basically nothing except the Power source should be connected while you are booting up your computer. You can install the USB devices once your computer has loaded up.
Jul 18, 2010 | Acer eMachines eM2501162 Netbook
Computer freezes on start-up
whenever your doing a cd recovery you need to remove the battery
use ac power
if its still freezing up you'll have to run windows again
Windows uses a lot of power to install
Jan 09, 2009 | Acer Aspire 3000 Notebook
Computers & Internet Logo
David Payne
David Payne
